ECM question
Old Apr 11, 2016 | 08:06 PM
BobRoy's Avatar
Default ECM question
I'm looking to buy a 97 XK8 that has transmission issues. I have a spare 97 transmission that will take care of that issue. My question is the owner of the car bought it for its ECM that he was going to put in his 97 XK8 that had ECM issues. He took the ECM out of the car i'm looking at. He found out that it didn't match up to his car. My question is if I reinstall the ECM do I have to do anything ( program- hard reset )or just plug it in and i'm to go?
Old Apr 11, 2016 | 09:50 PM
motorcarman's Avatar
The 1997 ECMs are one of a kind as they have no link to a KTM. Jaguar started using keys with transponders in 1998. The ECM for 1997MY XK8 is NLA from Jaguar.
My buddies at the Jag dealer I worked at years ago called me to ask if I had a good used ECM for 1997 XK. I did not so they had to send the old one out to get repaired.
I don't think you need an 'immobilization-setup' for the 1997 XK. There might be a difference between Conv and Coupe??? VCATS will be your friend.
The ECM SHOULD be a 'plug & go' if it is the correct part number (software version).
bob
Old Apr 11, 2016 | 09:56 PM
BobRoy's Avatar
Sorry I might of not explained it clearly but i'm puthing the original back in. Just curious if I'll have any problems. Thank you for your response.
Old Apr 12, 2016 | 02:30 PM
dsnyder586's Avatar
You should have no issues swapping the transmission unless there is a problem with the TCM.
Old Apr 12, 2016 | 02:33 PM
RJ237's Avatar
There should not be a problem putting the original ECM back in.
Old Apr 12, 2016 | 05:56 PM
BobRoy's Avatar
Thank you for your responses I did not buy the car the interior was in too bad of shape. It wasn't worth the price he wAntes and I do not need another parts car. But the information about the ECM is good to know
CyJag
59
Oct 21, 2016 04:33 PM
MediaBobNY
Apr 15, 2016 04:07 PM
webshark
Apr 12, 2016 05:16 PM
Foghorn14
Apr 11, 2016 09:08 AM
