ECU failure - instrument cluster
Old Sep 18, 2023 | 08:53 PM
chillyp's Avatar
Default ECU failure - instrument cluster
Hello,
Bringatrailer has an XKR listed for auction that is less than a couple miles away from me. It is a project car (car needing work with failures). The description says
An invoice from September 2022 indicates that the ECU was replaced in an effort to address a non-functional instrument cluster. The replacement ECU “has failed” and “is locked,” per the invoice, and the selling dealer indicates that the cluster displays a variety of warning lights and messages. The analog gauges do not work, the digital odometer shows 839k miles, and total mileage is unknown. The instrumentation does not work and the gauge cluster displays various warning lights and caution messages, a problem that is said to have developed after the ECU was replaced in September 2022.
I am considering bidding for the car on account of the distance from me. I've not worked on any electrical or electronic issues with cars, before I spend a few thousand on these, what are your thoughts on (a) the likelihood that the ecu has actually failed vs some other reason for failure? (b) any questions I should ask the dealer to gain confidence on a failed ecu vs some other reason for instrument cluster failure (c) how difficult would it be to get a replacement ECU? and how likely that another replacement would fail due to no addressing the underlying cause.
Old Sep 19, 2023 | 02:29 AM
dibbit's Avatar
Its more likely the instrument cluster that has failed rather than the ECU. Just one of many threads on the subject here, along with a link to the TSB:-
https://www.jaguarforums.com/forum/x...repair-265687/
By the way, if the car starts and runs the ECU is working.
Old Sep 19, 2023 | 06:35 AM
chillyp's Avatar
Thanks Dibbit.
Old Sep 19, 2023 | 09:38 AM
michaelh's Avatar
Curious:- what year is the XKR?
Old Sep 19, 2023 | 10:03 AM
xalty's Avatar
whoever was on that repair order sucked and had no idea what they were doing
Old Sep 19, 2023 | 01:10 PM
chillyp's Avatar
https://bringatrailer.com/listing/20...convertible-4/
Definitely sounds like that, they seem to have also discarded (or kept to themselves) the original ECU on the car and it is no longer available with the sale.
Old Sep 19, 2023 | 03:56 PM
motorcarman's Avatar
A replacement ECM for the 1998 North American XK8 will need an IMMOBILIZATION SETUP to introduce the new ECM to the CAN bus.
The engine WILL NOT START without the immo-setup.(the 1997 should start as the RFID transponder keys were introduced for the 1998MY Jaguars in North America)
Old Sep 19, 2023 | 07:53 PM
RJ237's Avatar
To get this 2000 XKR operating you will need to take it to a shop with the necessary software to do the immobilization setup and also replace the instrument cluster at the same time. Then, if it turns over, you may have to replace the fuel pumps and possibly also the chains and tensioners. If you're lucky, the total cost would probably be in line with the market value, but could easily be much higher.
Old Sep 20, 2023 | 02:20 AM
dibbit's Avatar
Originally Posted by chillyp
From the listing:-
"This 2000 Jaguar XKR convertible is a running-and-driving project"
Which strongly suggests the ECU is fine and it doesn't need an immobiliser setup, just a new instrument cluster, or the existing one repaired.
Old Sep 20, 2023 | 06:10 AM
RJ237's Avatar
Further down they claim the ECU has failed and is locked. A request was made yesterday to clarify whether the car does run and drive.
Old Sep 23, 2023 | 06:46 AM
chillyp's Avatar
Cor sold for 13k which I thought was ridiculous given there were no records of maintenance (tensioners / chain / thermostat housing) etc. and came with an un-diagnosed issue. It is crazy/
Old Sep 24, 2023 | 03:58 AM
dibbit's Avatar
It is a nice looking car though and the winner (comment copied below) sounds like they know what they are doing, so they will probably just swap the instrument cluster for a replacement and have a running car:-
Thank you everyone! Im excited to get my hands on it. I have a 2000 XJR already, so this will be great to add to the collection. I own an Automotive Repair shop that specializes in complicated electronics, so this is going to the perfect place!
Old Sep 24, 2023 | 04:24 PM
chillyp's Avatar
Yes, that is true. For me tho, it doesn't make sense when one just as good with no issue sold for 13.5k two days prior. I'd have liked to take a look and see what is up with this car but somewhere around the 8k point the bidding went out of the sensible range and mostly bonkers.
jacobmstein
Jul 21, 2020 02:32 PM
rjulius
Feb 24, 2019 03:19 AM
Mountaineer
May 6, 2017 02:17 PM
smartobject
Jun 15, 2015 02:25 PM
Prodriver365
Mar 7, 2013 04:45 PM
