Electrical Fault
Old Sep 5, 2014 | 09:04 PM
kench's Avatar
Default Electrical Fault
2001 XK8 is getting funky again!
I put a new battery in this summer, so that shouldn't be the issue.
After putting the top down, I got an "electrical fault" message, and the shifter won't go out of park.
I took out the star screw and did the manual override to get it out of park.
When I got home, the top wouldn't go up.
So I did the manual top raising, and jumped the 3 and 5 pin to raise the quarter windows, but how do I get the door windows up?
There must be a jump system to that too? I hope!
I tried to jump the 3 and 5 of the relay in back of the relay that controls the quarter windows, but all that did was make a click and get my paper clip really hot!
I've searched for an answer on the forum, but come up short.
Any idea on how to raise the drivers and passenger door windows?
I'm going to disconnect the battery all night and try again in the morning.
I just paid the car off yesterday! I'm not happy!
Old Sep 5, 2014 | 09:25 PM
Gus's Avatar
Gus
Check your battery voltage first then do a hard reset and see what takes place.
Old Sep 5, 2014 | 09:26 PM
test point's Avatar
First guess is that your battery problem extended beyond a bad battery. Probably time for a complete charging system check at your local auto parts store.
Beat me by a minute GUS!
Old Sep 5, 2014 | 09:39 PM
motorcarman's Avatar
If the locking and security system is still working you can close the windows with the key in the driver's door turned to LOCK and hold it.
bob gauff
Old Sep 5, 2014 | 09:44 PM
kench's Avatar
Battery is at 12.22 volts with car off.
Tried the hard reboot (neg cable to positive for 15 seconds) and it still has "electrical fault" and door windows won't go up.
Car is idling now for ecm to get back into it's groove.
Old Sep 5, 2014 | 09:56 PM
kench's Avatar
Key in drivers door and held at "lock" doesn't raise windows.
Key fob won't work either.
I just disconnected positive battery cable and I'll let it sit all night.
Really not looking forward to a 45 minute one way ride to drop it off at my mechanic!
Did I mention I just paid the loan off yesterday!!!!! Can you say "frustrated"?
Old Sep 6, 2014 | 11:03 AM
Gus's Avatar
Gus
Have you checked your inertia switch? It will turn off power to your engine, fuel, windows and a bunch of other stuff.
Old Sep 6, 2014 | 11:19 AM
kench's Avatar
Haven't checked the inertia switch yet.
I reconnected the battery this morning, and the quarter windows automatically went down! Had to jump pins 3/5 again to get them up.
Turned on key, and both door windows went up! Then "electrical fault" came back on the dash and the windows wont move, key fob won't work.
And to top it off, the passenger door window went down a little when I opened the door, and it won't go back up.
It's gonna be a noisy ride to the mechanic!
Old Sep 6, 2014 | 11:31 AM
Gus's Avatar
Gus
Check your PM
Old Dec 12, 2014 | 11:03 AM
kench's Avatar
I ended up bringing the car to the Jag dealer. They had it for 12 1/2 weeks! Thank god they gave me a 2013 Range Rover as a free loaner car. After 3 months, they discovered that the problem was the head rest modules were both shorting out. New modules were $2100. I opted for them to just disconnect the modules, and not have movable head rests. Never used them anyways. The said I was luck the seats didn't catch on fire, the wires were pinching and the insulation was worn away, they were melting on the inside. $915 later, the car is back home!
tomsjag
Jun 10, 2023 10:02 AM
scooternva
19
Oct 27, 2015 02:14 PM
Dixie61
Sep 19, 2015 06:29 AM
frank regalado
Sep 16, 2015 06:15 AM
tonyforman
Sep 10, 2015 07:23 PM
