electrical gremlin, says passenger door open when it is not.
Old Oct 8, 2011 | 08:47 PM
OhioXK's Avatar
Default electrical gremlin, says passenger door open when it is not.
I noticed that the interior lights in my '03 XK8 were stuck on while the car was parked so I went out to investigate. They seemed to be on for no reason, the doors were closed, and at first I was not getting the 'passenger door open' signal. I opened and shut the doors several times, and I *believe* but cannot confirm that the windows were opening and shutting themselves slightly as they should at that point.
I then heard the passenger window actuating repeatedly, but only momentarily, while the interior passenger door light would turn on and off simultanesouly. Then I got the passenger door open message.
At this point I went to inspect for any obstructions in the passenger door, and when I grabbed the outside handle the window lowered itself a few inches. I pulled (slightly) on the handle again several times, each time the window lowered itself an inch or more.
I thought maybe the windows needed to be reset, so I did that per the instructions in the manual, to no avail. I still had the same problem.
I then disconnected the negative battery cable for a few minutes, reconnected it, and reset the windows again. I *think* that it's been OK since then.
I'm not sure what might have brought this on. The only thing I can think of is that earlier today I washed the car and left the doors open for a very long time to let everything dry out.
Anyway, I'm not sure if this is fixed now or not. Any suggestions as to what may have caused this or what I should inspect?
edit: just found this thread: https://www.jaguarforums.com/forum/x...or-shut-25020/ about something very similar. I hadn't driven the car for nearly two weeks until yesterday due to inclement weather. maybe the battery is a bit low.
Old Oct 8, 2011 | 09:03 PM
Gus's Avatar
Gus
It is hard to say if the door and window are now working properly. These cars are plagued with a series of poltergeist events and most are caused by a battery that is not up to par. The door latch has 3 micro switches and a door control module. For now if it is ok wait see what takes place.
99xk8guy
Sep 29, 2025 10:51 PM
dsnyder586
Dec 29, 2024 07:39 PM
99xk8guy
May 28, 2024 09:36 PM
Rivguy
Dec 4, 2020 07:55 AM
XJsc-guy
Nov 23, 2015 01:56 PM
