Eliminating Convertible Headliner
I am the new owner of a 1997 XK8. It stopped running in 2017 and the previous owner let it sit for the past 5 years. It had numerous electrical issues that I worked through and got it running again (thanks to all the great information on this forum) but now I am dealing with the aftermath of it sitting with windows partially down. The interior has been host to water for some time before a cover was finally placed on it. There is an abundance of mold and mildew on all surfaces. I have been able to clean all the surfaces but the headliner is horrible with the inability to properly clean it. I am faced with either replacing the top and headliner which I will have to do someday (the top is in OK shape) or remove the headliner and live without it until the day arrives when all is replaced.
My question is: has anyone simply removed (cut out) the headliner and moved on? I understand the interior won't be as beautiful and more old school in appearance but is there anything I should be concerned with if I go this route?
Thanks all for your thoughts.
P, FYI you can clean the headliner with brake cleaner in case you want to try. I remember when someone posted this years ago. I thought they were crazy, but it works, no damage.
John
John
Thanks John, That is interesting and worth a try. The sad truth is that mold is all over the headliner....not just where visible. This is a health related issue more than an appearance issue. It has to be removed and there are parts of the headliner I can see but can't reach to properly clean. I am fine with taking it off and washing it but then again it is 25 years old and a replacement would be more advisable. I am just considering my options until such time as I have the funds to replace it properly.
Interesting. Mine looks more like black splotches. I actually had to use a Tilex type of spray to get any results. This worked well on those areas I could reach to apply, scrub, vacuum and repeat. The Clorox works but will ultimately damage the fabric. I will see if I can post a few pictures of the issue when I get back home. Thanks!
You are right about nothing to lose. I will be giving the break cleaner a try. Plan B will be to purchase a replacement assembly. Does anyone know if any replacement assembly from 97 to 2006 will work or were some changes made to the mechanism I should be aware of?
Thank you all again for the sage advice.
Have you thought of going to your local fabric store and get a close matching fabric? I did that when I had the green shower which ruined the headliner material....went to Calico corners fabric store and they had a really really close match to color and nap size to the original.....bought enuf to redo the A&B pillars and headliner...can't tell the difference. More than likely, if doing the entire convertible headliner, I would take off the old one carefully and in one piece if possible and have a professional seamstress make a new one. Just a thought.
fourkegdave, That is an excellent idea! I will have to replace the top someday but will kick that can down the road. I can re-use the headliner when that day comes. Thank you (and everyone) for your thoughts.
IF you can remove your current headliner in one piece you can take it to a place that cleans rugs and have them professionally clean it. Then reinstall. Just a thought.
ThosMa
Apr 30, 2021 09:42 PM
