View Poll Results: Do you have alternative access to open your hood or trunk?
I have no alternative access.
55.56%
I have alternative access to the trunk only.
33.33%
I have alternative access to the hood only.
0%
I have alternative access to both the trunk and hood.
11.11%
Voters: 9. You may not vote on this poll
Emergency Access to Hood,Trunk Poll
Old Dec 8, 2018 | 09:12 AM
Dr. D's Avatar
Default Emergency Access to Hood,Trunk Poll
Howdy Folks:
Without disclosing any of your "secrets", I am curious to know of those who have rigged an alternative access to opening their hood (bonnet) / trunk (boot) lids.
In my case, I can mechanically, by just using my hands, open my trunk in <10 seconds or my hood in <60 seconds. I am not bragging, but just thinking that I am not the only one.
Thanks for sharing.
Old Dec 12, 2018 | 09:39 AM
MikeAlford's Avatar
On the XK8 you can unlock the trunk with the key inserted in the hole on the XK8 badge located on the rear?
Old Dec 12, 2018 | 08:20 PM
attaboy's Avatar
My thoughts exactly, but of course that does require the key, or at least the valet key. If there is some secret key portal for the hood I'm not aware of it.
Old Dec 13, 2018 | 05:30 AM
Originally Posted by Dr. D
..... I am curious to know ......
I am curious to know why you would start a POLL on this topic instead of an ordinary thread.
Old Dec 13, 2018 | 07:29 AM
Dr. D's Avatar
Hello Graham:
After over 300 views, I wondered about that myself. I thought that maybe I should have added an option to vote something like: "That is my business".
I have had trunk access for several years, and it is completely reversible. I also at that time, could not come up with a completely reversible solution for the hood. That bugged me for the longest, and finally earlier this year, I came up with a solution that was as stealth as my antenna switch. Both of my lids operate as they should, but I like the security of just knowing that I have a quick way out instead of the likes of holes behind the license plate, going through the taillight, or through the front fender liners. (I have used my trunk method at least a half dozen times for various reasons including closing my keys in the trunk and access to battery tender)
I was thinking that even if one did not want to vote, that they would share their thoughts in the poll replies.
I agree that if to be redone, I would go with an ordinary thread.
Thanks to all that have viewed or replied.
Old Dec 13, 2018 | 06:14 PM
Gus's Avatar
Gus
I am in! Would like to see where this is going.
Gus
www.jagrepair.com
Old Dec 13, 2018 | 06:55 PM
sweez's Avatar
I thought the valet key won't open the trunk?
Old Dec 13, 2018 | 08:02 PM
zray's Avatar
OK, I'll bite. I've got no key but need a secret method or password to open the trunk or hood.
Abra-ca-dab-bra..... presto like magic the trunk and hood are now open, but I still ain't got no key ???? What now ???
Z.
Old Dec 14, 2018 | 03:49 PM
Dr. D's Avatar
Z.
Z :
I have no idea of how to run "keyless". I handled the hood an trunk mechanically, but some years ago (someone correct me if I am wrong), Steve -Jagwrangler-WhiteXKR envisioned electronic trunk access via simply pressing the button on the trunk with a password.
Old Dec 14, 2018 | 04:44 PM
zray's Avatar
Z :
that must be similar to what Ford had a few years ago for door entry, there were 5 buttons adjacent to the door handle numbered 1-2, 3-4, 5-6, 7-8, & 9-0. you entered a 4 or 5 digit code for the door to unlock. Still had to have a key to start the car though.
Z
Old Dec 14, 2018 | 05:05 PM
Gus's Avatar
Gus
Yes Steve and I talked about this and he put it on his list of things to do but to date I haven't seen it. I would suggest asking him about it.
Gus
www.jagrepair.com
Old Dec 14, 2018 | 11:38 PM
gjensen's Avatar
It would be interesting to see some of the solutions that have been used.
Old Dec 15, 2018 | 05:01 AM
astromorg's Avatar
Let me resurrect this that I posted here six years ago as an easy practical solution
https://www.jaguarforums.com/forum/x...emergency+boot
Old Dec 15, 2018 | 09:59 AM
Dr. D's Avatar
Astromorg:
Thanks for the link. It is probably the one that I remembered concerning Steve's password.
I had done my trunk fix about 20 months prior to your post. Although your method exposes the "orange lever" and is a completely different approach than mine, they have the exact same end result.
It is well worth saying again that anyone who gets anywhere near that " orange lever" should heed your
WARNING:
"An important point is to note is that orange plastic capped lever - while it's Up, all is well, but if you inadvertently push it Down and leave it in that position, the boot lock becomes inoperable by the fob, the key or the boot lid button - you've been warned!! "
Old May 21, 2022 | 05:21 PM
JagChic's Avatar
Howdy Folks:
Thanks for sharing.
HOW? I've locked my ONLY key in trunk with car in VALET mode. Watched COUNTLESS videos of people suggesting the "secret" key hole which is of no use when there is no key and obviously the release button is disabled. So as the top is down and storms a'rollin in we have drilled quite the collection of holes behind the license plate to no avail. Locksmith wants $450 and dealer quotes a 2 week wait. ANY HELP ON ACCESSING TRUNK would be appreciated
astromorg
Sep 17, 2023 06:15 AM
rf69
Dec 12, 2018 10:18 AM
Hex Type
Apr 4, 2015 10:28 AM
astromorg
Dec 28, 2013 09:19 AM
astromorg
Aug 23, 2012 03:48 PM
