Engine “surging” at low revs
I have recently noticed that when driving my 1997 XK8 at low revs (1000 -1500 rpm) there is a slight “surging” of the engine note. A small oscillation of the rev counter can also be seen between these values. This normally happens whilst driving through an urban area at speeds of up to 40 kph. Once above 1500rpm the surging disappears. No DTCs are recorded. Any thoughts? Many thanks.
In 2011 I had a similar issue in my 2005 XJ that turned out to be the torque converter not locking up properly. Consistent but subtle RPM fluctuation was most noticeable at steady speeds like on the highway. After replacing that all was back to normal. I was fortunate that the car was still under Jaguar extended warranty.
I must admit that I have never noticed the revs to vary at higher speeds & low revs only at low speeds & low revs.
I´ll be sure to check this on my next outing!
Cheers.
Yeah, a tps with a "flat spot" could indeed cause a surge as the thing overshot one way, then the other.
Don't know about XK8 or XKR but a lot of cars you can just unplug it. If surging doesn't go away, look 4 other causes.
Simply hooking up a vacuum gauge might reveal your problem, 30 seconds!
Could be resolved by reprogramming and reconfiguring the shift programme. Worked for me a few years ago. The TCM gets an update (trans reflash) and the adaptations get reset.
Hi Porterve,
I'm sorry to join your thread so late. I am attaching a TSB that contains diagnostic flowcharts that may be helpful.
If your engine idles smoothly without surging when in Park, one possibility that comes to mind is that your transmission may be "hunting" between two gears when you are traveling at steady speeds. Your transmission could also be slipping slightly due to low fluid.
Please keep us informed.
Cheers,
Don
Cheers,
Don
Same very mild surging issue with my 2003. At 30 mph and 1300 to 1500 rpm the tranny is in 4th trying to shift into 5th causing the surge. When I move the J gate to 4th the surging stops. Definitely the tranny in my simple mind.
Hello all. Please accept my apologies for not responding sooner but have still got the front wheels off investigating a leak! As soon as I get a chance I’ll take her for a spin & let you know what I find.
Many thanks for your suggestions.
