engine check light
Old Jul 6, 2014 | 11:43 AM
tony bosco's Avatar
Cool engine check light
problems problems problems................... engine check light came on yesterday, had it checked at auto zone reading said fuel problem? lately the gas needle has been sticking and would go to E when theres 1/2 tank then would bounce back... sometimes would have to shut car then restart then it would go back to 1/2. codes are : po171 po174 & po1111
* fuel injection system to lean ?
*IVT control solenoid valve circut ?
* MAF sensor ?
any thoughts or sugestions.....
tony
Old Jul 6, 2014 | 12:02 PM
RJ237's Avatar
Please provide the actual code. The generic readers often give misleading explanations.
Old Jul 6, 2014 | 12:54 PM
Paul Pavlik's Avatar
P1111 - Emission Monitors Complete.
P0171 & P0174 - Both Banks Lean Mixture.
Try checking for Vacuum Leaks and Leaks in Air Intake Tube.
Also Clean MAF Sensor and Electrical Connections to same.
Old Jul 6, 2014 | 03:05 PM
RJ237's Avatar
Thanks, Paul. I read his post and didn't even see the codes.
Old Jul 6, 2014 | 05:38 PM
tony bosco's Avatar
Cool engine light
thanks paul & RJ.. i'll try cleaning the maf sensor and the connections.... after i clean them should the light go out if that was the problem or should i have the engine light cleared and then see if it comes back ? to clean do i have to take maf off and apart or just unplug and clean the connections
not to famillar with all this.. did watch a u-tube video on it though!!!!!!!!!!!!!
Old Jul 6, 2014 | 06:19 PM
After Repairs you can clear the codes immediately with a Scan Tool or the Codes will clear after one or more Required Driving Cycles.
Air Leaks AFTER the MAF will cause the Lean Mixture Condition.
Old Jul 6, 2014 | 06:58 PM
Jandreu's Avatar
Only use MAF spray cleaner..do NOT touch the sensors. Take out the two screws, unplug the wire and remove. You will have a plastic device with a sensor inside a tube and a tempurture sensor on the outside of the tube. Spray everything very well with the MAF cleaner, let dry and reassembly.
Old Jul 6, 2014 | 07:32 PM
tony bosco's Avatar
Cool
hope its not to late. might have touched............ where do you pick up the maf spray cleaner......... auto zone ?
Old Feb 28, 2015 | 01:43 PM
drk1074's Avatar
Yes, Auto Zone, among others.
Old Feb 28, 2015 | 04:13 PM
RJ237's Avatar
You are responding to a question posted last July. I would hope he has found the MAF cleaner since then.
What year/model Jag do you have? If you click on the USER CP at the top left of the page you can add that info to your signature.
BrentGardner
29
Dec 16, 2024 12:13 AM
JeffR1
Sep 12, 2015 10:43 AM
niner nellie
Sep 1, 2015 10:53 PM
SingBlueSilver
Aug 27, 2015 02:20 PM
daro31
Aug 27, 2015 09:26 AM
