Engine light stays on after battery unhooked
Old Feb 11, 2022 | 06:03 PM
cap7247's Avatar
Default Engine light stays on after battery unhooked
My 2000 XK8 jag convertible engine light went on after AAA towing company came and unhooked battery hooked as hooked it backup. Since then the engine light won't go off. Wasn't on before that. No codes show up when Pep boys checked. We Have unplugged negative black cable as recommended but engine light still on. Anybody have ideas? Car runs fine, no issues. Thanks for any help!
Old Feb 12, 2022 | 05:33 AM
I've moved your question from US Western Region to XK8/XKR forum. This is the place to post technical questions about your model.
Old Feb 12, 2022 | 08:09 AM
RJ237's Avatar
You didn't disconnect the cable with the engine running, did you?
Old Feb 13, 2022 | 01:12 AM
Pistnbroke's Avatar
This is a common alternator fault caused by a shorted field diode ....ign OFF warning light ON. New alternator or diode pack. This applies to what in the UK is called the ignition warning light not an engine fault light. Most alternator faults allow the alternator to still give some charge thought this may be as low as 8A.
Schweppes
Australia - Western
Feb 9, 2022 02:51 AM
Friday
Jun 20, 2018 05:56 PM
Injekter
Apr 20, 2015 08:28 AM
magnum454
Apr 11, 2014 10:02 PM
divetdan
Jan 12, 2014 05:15 PM
