Engine mount getting compressed over time?
Old Feb 15, 2019 | 08:49 AM
Higgins's Avatar
Default Engine mount getting compressed over time?
Today I replaced the passenger side engine mount on my Xkr 4.0. It was tricky but since control arms and all other stuff was already removed from the wheel well it was done in one hour. When I got the old one out I realized it was about 10 mm shorter compared to the new one (bought from Sng Baratt). Is this to be expected?
Old Feb 15, 2019 | 09:45 AM
bladerunner919's Avatar
Yes. You'd probably get a bit squashed if you were holding the engine up as well!
Old Feb 15, 2019 | 09:56 AM
Higgins's Avatar
You are probably right..
Now to the trickier driver side. How the hell am I supposed to:
1 Get the nut at the top of the mount off
2 Get the old mount out of the non-existing space between the engine block and the engine compartment wall
3 Get the new mount into the same space
Old Feb 17, 2019 | 07:44 AM
Higgins's Avatar
Anyone that has replaced the engine mounts and are willing to share the lessons learned?
Old Feb 17, 2019 | 10:31 AM
Sounds like a lot of fun, let us know how you get on.
https://www.jaguarforums.com/forum/x...-mounts-64960/
Old Feb 17, 2019 | 04:15 PM
Higgins's Avatar
Thanks a lot! Just what I thought, have to drop the steering rack. Lets get to it.. 😣
Old Feb 17, 2019 | 06:12 PM
giandanielxk8's Avatar
Please take pictures.
Old Feb 20, 2019 | 03:38 PM
Higgins's Avatar
Got it solved! 5-6 hours spent to change the driver side engine mount. My solution was to create a special tool to undo the nut on top of the mount.
First I lowered the steering rack and discoupled it from the steering column via the splined axle.
Base of the tool I made is a swivel socket spanner (15 mm socket). The socket spanner itself I was able to get on the nut, but not able to apply torque enough in the tight space. So I added some stuff to the spanner so that I was able to push it with support from the engine compartment wall. The other parts of my special tool is a bolt with two corresponding nuts, a specially made piece from a square Iron tube to fasten the wrench to the bolt and a 13 mm socket as an end piece to put towards the engine compartment wall.
When the wrench is in place at the nut on top of the engine mount I start expand the special part of the tool via one of the nuts on the bolt, so that the 13 mm socket at the end of the bolt pushes into the compartment wall. First using fingers, later an open spanner. This way I slowly push the swivel socket spanner towards the engine block, loosening the nut. It was turned approx a quarter of a turn and that was enough to soon get it loose completely.
With the steering rack lowered I was able to get the old mount out and the new one in. One issue was also that I was not able to see the bolt on the top of the mount when lowering the engine again after being jacked up. The bolt dont center itself for the hole in the bracket above it
Old Feb 20, 2019 | 03:52 PM
Good job! Thanks for the update.
Old Feb 20, 2019 | 05:50 PM
michaelh's Avatar
Great piece of creative thinking.
M
apexjag
Sep 24, 2019 12:52 AM
Siebert22
Mar 8, 2016 04:17 PM
PinnacleWax
Detailing / Car care
Sep 16, 2015 10:28 AM
jepjrmd
Aug 6, 2013 07:53 AM
jagosaurus
Sep 7, 2012 12:36 PM
