Engine oil pan gasket blown
Old Jul 16, 2013 | 08:39 PM
fastscot's Avatar
Default Engine oil pan gasket blown
My 2003 XKR just blew the engine oil pan gasket (lower) the other day. Fortunately I got home before all the oil was gone so no damage. Is this a common occurrence or was I just unlucky? Although the car is 10 years old it still has only 40K miles on it. I'm assuming there was no other underlying cause such as excessive crankcase pressure since there were no DTC or any other fault codes which would point to a faulty PCV etc.. I already have a new gasket ready to fit. Any comments please?
Thanks,
Neil
Old Jul 16, 2013 | 09:13 PM
test point's Avatar
Strange . . . .
Never heard of a blown oil pan gasket without severe blow by from cylinder compression.
Best understand what cause the gasket to leak rather than just replacing it.
Old Jul 17, 2013 | 12:02 AM
dsnyder586's Avatar
Odd. Were the bolts loose maybe?
Old Jul 17, 2013 | 04:50 AM
An unusual and possibly even unique event.
Is the Oil Pan damaged?
Old Jul 17, 2013 | 05:23 AM
test point's Avatar
I did have a Ford Taurus 3.0L that blew out the front oil seal due to backfires caused by failing spark plug wires.
Had any such issues?
Old Jul 17, 2013 | 07:01 AM
oldmots's Avatar
First time I have heard that one. The crankcase vent system should be capable of handling any pressures that could do something like that. If it happened to me, I would look around for blockages in the cranckcase vent and carefully torque the new gasket down. Unless you have a lot of piston ring blowby, this is probably caused by a loose pan. You can verify that all is well by doing a compression test and a leakdown test to be sure what is in the cylinder stays in the cylinder.
Old Jul 17, 2013 | 12:05 PM
fastscot's Avatar
I could kick myself! I misdiagnosed the problem. The oil cooler hose was leaking at the ferule which DOES appear to be a fairly common occurrence. I guess I didn't look closely enough as to where the oil was coming from. Ordered a replacement hose (C2N2208) so should be up and running again in a few days. Thanks for all your comments. Anyone need an oil pan gasket! I paid $40 including shipping so I'll send it to anyone who wants it for $30 incl. shipping.
Neil
Old Jul 17, 2013 | 12:25 PM
WhiteXKR's Avatar
Yes...that is a very common issue.
D.K
Dec 10, 2023 02:05 AM
kelliott
May 31, 2022 05:26 PM
bdboyle
Sep 4, 2015 06:16 AM
pnwrs2000
Sep 3, 2015 11:55 AM
OkieTim
Sep 2, 2015 12:48 PM
