Engine and possibly tranny removal
Old Sep 15, 2015 | 04:19 PM
TreVoRTasmin's Avatar
Default Engine and possibly tranny removal
Finally getting finished stripping my parts car. Last thing to take out will be the engine. The radiator and front clip are already gone so front access is pretty good. It is however sitting in a stone lot and isn't roll able (front hubs gone). I don't have any need for the tranny as it is toasted and mine is a fresh rebuild so don't have any interest in keeping it as I don't have the space but the engine is a runner. Can someone give me the low down for removing it. Seems like the exhaust pipe bolts are easy enough to get at as is the top bolt for the motor mounts. What am I looking at needing to do to sep. the tranny and engine. Oh and if anybody needs anything off a 97 brg and tan interior speak now! Hope to send the shell off by the end of the month or early Oct.
Old Sep 15, 2015 | 05:20 PM
jimforrest (uk)'s Avatar
Remove the Throttle Body, the aux heater pump, and hack off all of the pipes into the firewall. You can then get at the 'bell housing'.
Old Sep 15, 2015 | 07:46 PM
DaveInVA's Avatar
Are the front seats decent?
Dave
Old Sep 15, 2015 | 08:42 PM
Upper divers seat was pretty bad for a coupe, I actually installed the pass seat in mine and am going to have the top cover switched with the pass side from my car so that I can get heated seats. Sorry.
Old Sep 15, 2015 | 09:41 PM
Guessing there are 2 bolts up top, the starter and another bolt down below. What about a flexplate?
Old Sep 15, 2015 | 10:35 PM
mrplow58's Avatar
The starter should come out with the engine, and the torque converter will come out attached to flex plate, connected to the engine, when it is pulled. I would burn the bolts off the catalysts, and then burn the exhaust off, just before it connects to them...Mike
Old Sep 16, 2015 | 08:14 PM
No torch available but if I cut down after the cats will the whole thing come out if pulled forward? Would like to try to save the cats if I can for spares
BrentGardner
29
Dec 16, 2024 12:13 AM
Rupesh
Mar 25, 2016 03:33 PM
montypeek
Sep 6, 2015 04:57 PM
jagy4321
Sep 3, 2015 07:56 PM
dpappyp
Aug 27, 2015 06:31 AM
