engine stalled message
Old Mar 31, 2008 | 09:05 PM
97xkay8's Avatar
Default engine stalled message
Starting/stopping all day (running fine) and then on the way home rpms drop to nothing and I roll to a stop. Dash says "engine stalled". I shut it off and fired it back up, went about a block and the same thing. Repeated cycle and drove it home ok (10 min to house)
Sound familiar to anyone?
Thanks,
Marv
Old Mar 31, 2008 | 09:11 PM
JagtechOhio's Avatar
Default RE: engine stalled message
XK,
I take it this is a '97 XK8, and that you checked for DTC codes and got none?
And you had a throttle body recall/ reflash performed already? If yes to all,
Initial guess would be fuel pump failure, or more specifically, burned fuel pump link lead terminals. Search for "DeShan" on the place with all the flies, I think that was his name.
Old Apr 1, 2008 | 06:25 PM
jag_genius's Avatar
was this after you installed the rebuilt ecm?
Old Apr 2, 2008 | 06:12 PM
97xkay8's Avatar
Yup.
ECM rebuild in Nov. (1st time stall since I boughtcar in Nov)
Codes cleared about a week ago (see "no commo" thread).
Reflash done on pre-rebuild ECM.
Throttle body recall? (doesn't look like orig. throttle body)
Fuel pressure OK (last I checked)
VIN VC003032
Talkedto mech and saidcrank position sensor was one of codes.
I'm gonna get it changed.
Old Apr 2, 2008 | 08:36 PM
FactoryJaguarTech's Avatar
What Ohio was saying was the fuel pump terminals get bad and cause car to stall. 99% of the time when you get the message saying Engine Stalled, it is fuel issue. I would replace the relays in the trunk fuse box and the engine management fuse box first. The relays on the 97 XKs were a disaster. If problem persists after that, go for the fuel pump. Easy to tell. Stick a fuel pressure gauge on car, tape it to windshield and go for a drive. See if pressure dies off while driving. This could still be either/or with pump or relays until you change one. Relays are cleaner, faster and cheaper.....lol.
Old Apr 2, 2008 | 08:41 PM
jag_genius's Avatar
since you got the crank sensor code.. i wud go with that probably was shorting before and caused the ecm to burn.. and if it is the crank sensor.. it will burn your ecm again.. had the exact same thing.. 1997 xk
you can check fuel easy to do.. crank sesnor not so easy to do..
Old Apr 2, 2008 | 08:44 PM
lol....thats harsh him editing his message to add crank sensor code while I am typing response to original message.
Old Apr 2, 2008 | 08:48 PM
jag_genius's Avatar
yeah i thought that .
Old Apr 2, 2008 | 08:50 PM
97xkay8's Avatar
Changed out fuel pump relay in trunk a few weeks back. There is a fuel relayin engine compartment, too.
79000 miles on car. Are thereany relays that I should replace as preventive maint ? Or keep on hand? I'm all for a few dollars now than a wrecker later.
Thanks J_G. I remember you mentioning that.
I gots to buy me my own scanner !!!!
Old Apr 2, 2008 | 08:54 PM
jag_genius's Avatar
there was an update on the relays... replace them all together. under the hood..
Old Apr 2, 2008 | 09:35 PM
97xkay8's Avatar
Please excuse my "harshness".
It was never my intention to violate the rules of cyber chat....
You guys are too quick on the answers... and I still use dial-up.
'97 pardons, Marv
Old Apr 2, 2008 | 10:36 PM
Both FJT and Genius teach me something everytime I tune in. People should appreciate their help and this forum. Thanks, guys!
Old Apr 3, 2008 | 06:35 AM
Lol 97 I was kidding. My answer was in vain due to the ckps code you had. I found it amusing.
Old Apr 3, 2008 | 08:22 PM
jag_genius's Avatar
lol
Old Apr 3, 2008 | 10:12 PM
97xkay8's Avatar
No prob, FJT.
I don't take anything serious... except driving my firetruck and nudiebars. ROFL
To know me, Is to love me.
Thanks to all, as always.
Marv
PMKimpton
Aug 3, 2019 08:22 PM
cissdm
May 3, 2016 06:02 AM
pegasus3710
Sep 5, 2015 09:40 AM
XFR_Gold
Sep 2, 2015 12:24 PM
innzane
Sep 2, 2015 10:08 AM
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
