Engine Temperature Light
Old Apr 13, 2023 | 08:53 AM
JACKP's Avatar
Default Engine Temperature Light
On my 2005 XK8 There is a red light at the top of the temp. gage that comes on when cold engine is started and goes off every once in a while, while driving. It is full of coolant. What is this telling me? Bad connection hopefully.
Jack
Old Apr 13, 2023 | 01:10 PM
zray's Avatar
Have you hooked up an OBD-II scan tool to see what the actual coolant temperature is at any given moment ?
That would be my suggestion to do first, just in case there is actually something strange going on. Once that worry is behind you, you can start checking the sensors and wiring.
Z
Old Apr 13, 2023 | 05:00 PM
JACKP's Avatar
Thanks Z. I'll have my son do that next week. I was stuck in traffic 80 deg F today for a while with no ill effects. But I will check as you said
Jack
Old Apr 14, 2023 | 02:58 AM
dibbit's Avatar
Have a look at this thread and confirm which red light you are talking about:-
https://www.jaguarforums.com/forum/x...solved-188018/
Old Apr 14, 2023 | 05:16 PM
JACKP's Avatar
Thanks for the link dibbit. The light that I am talking about is the rectangular light just to the right of the (H) on the gage between the 2 upermost marks on the scale. I haven't found anyting telling me what this light is for. I know it's not telling me my engine is hot because it is on when the engine is cold. When first cranked.
Jack
Old Apr 14, 2023 | 05:28 PM
zray's Avatar
Originally Posted by JACKP
”…… I haven't found anyting telling me what this light is for. I know it's not telling me my engine is hot because it is on when the engine is cold. When first cranked.
Jack
I believe your sensor and / or wiring is at fault as that is the light to indicate overheating .
Z
PS: section 3-3 of the Drivers Handbook indicates any red light within the instrument dials are for “primary warnings” . Which I take to be associated with the adjacent gauge. Which in your case is the temp gauge.
Old Apr 14, 2023 | 08:05 PM
JACKP's Avatar
Thanks again zray. I'll check it out.
Jack
Old Apr 15, 2023 | 02:41 AM
dibbit's Avatar
Jack
That isn't a warning light, its just the red segment of the gauge, all of which is backlit and can make it look like that top red segment is lit up. The warning light is top right and not part of the scale.
An OBD reader such as Torque will tell you the engine temp the car is reading - its worth checking to be sure.
Old Apr 15, 2023 | 05:06 AM
JACKP's Avatar
That's a relief. I wonder why it goes on and off. Backlight malfunction maybe?
I will check with OBD reader anyway.
Jack
Old Apr 15, 2023 | 09:36 AM
Johnken's Avatar
Jack, just an FYI. When the X100 reaches overheating temperature area, the air conditioning is automatically shut off by the ECU's programing.
Hope this helps you trouble shoot in the future.
John
Old Apr 15, 2023 | 09:38 AM
dibbit's Avatar
Jack
I think it might be an optical illusion. The red part of the gauge is brighter than the blue at the bottom, so depending on your dimmer settings, the red can appear to be lit. Try this test, which is how my 2001 behaves:-
Turn the ignition on. The back light on the scale comes on and the red warning light, top right, goes on then goes off (this proves if the warning light is working).
With the headlights off. The back light is on at a fixed brightness
Turn your headlights on. You can adjust the back light with the dimmer on the steering column, from dark to bright.
Turn your dimmer all the way down, so the back light is very dim. Now turn your headlights off - the scale back light will light more brightly and you might think that red segment on the scale has come on.
Fiddle around with the dimmer, switching your headlights on then off and see if you can make the red segment on the scale look like it is going on and off.
Old Apr 15, 2023 | 09:49 AM
zray's Avatar
On my 2005 XK8 There is a red light at the top of the temp. gage that comes on when cold engine is started…”
Not sure the shape of the high temp warning light on a 2005 model, but on my 2002 it’s an oval shape, and located above the H portion of the gauge, at the 1 o’clock high spot
As others have pointed out, the rectangular shape red indicator is just there to show the high temperature area of the gauge and is only backlit with the rest of the gauge.
if it’s flashing on and off it might be as simple as a bad backlighting bulb.
Old Apr 15, 2023 | 05:57 PM
JACKP's Avatar
The Temp warning light on the 2005 is oblong with rounded ends (race track shape}
Jack
Flcat
Jan 1, 2022 04:16 PM
warren8959
Apr 13, 2021 05:15 PM
Chuck Schexnayder
Aug 26, 2017 02:40 AM
motogirl_94518
Jul 15, 2012 12:23 AM
motogirl_94518
Jul 14, 2012 09:31 PM
