Oil Dipstick tube re-install question
Old Dec 14, 2013 | 05:17 PM
DrkNyte's Avatar
Default Oil Dipstick tube re-install question
I'm having a difficult time re-installing the Engine Oil dipstick tube. Does anyone hav a diagram or pics on how the tube should be routed?
I tried to feel my way into the correct groove but I don't know where the other end of the tube inserts into. I can't see it very well from any angle.
Thanks in advance.
Old Dec 14, 2013 | 06:28 PM
motorcarman's Avatar
I never have a problem because I NEVER PULL THE DIPSTICK OUT OF THE TUBE.
The dipstick is longer than the tube so it stays in the block and aids in reinserting the tube.
The hole is behind the aluminum mount bracket for the PAS pump and compressor.
good luck
bob gauff
Old Dec 14, 2013 | 06:55 PM
chopr's Avatar
You are right about it being hard to see down there! But it does simply "plug in" to the casting. Keep at it!
Old Dec 14, 2013 | 07:04 PM
test point's Avatar
I spent about as much time getting the tube back in as changing the tensioners. Finding the hole is the easy part. Has to be aligned just right and then it just slips in. Almost like it is a close tolerance machined fit which it really shouldn't be.
Old Dec 14, 2013 | 07:10 PM
DrkNyte's Avatar
If you ever end up making the same mistake I did or by chance ever need to replace the tube it's not easy and I couldn't find any instructions on JTIS.
Here's a summary for those with XKR or XK8:
removal is by tugging upward on the tube. As a workaround if you cant grip the tube you can insert a wire through the mounting bracket hole. This will give you somethig to grab onto with a vice grip pliers or something similar and smack it from the underside. Once it pops out of the hole in the engine it will be loose but you will have to pull on it while trying to angle the top of the tube towards the drivers seat. Wilth a little wiggle it will slip out.
Becasue of the bends in the tube it will not go straight back in. You will have to lay the tube with the top towards the drivers seat in between the wheel well and the exhaust mainfold. Force the bottom back in towards the engine keeping it as close to the engine block as possible. once it is far back enough try and tilt the tube upright. This is the moment of truth. If the tube is upright and you can't pull it out you are probably in the zone. but if you can see the bottom of the tube resing on the Pas Mounting bracket you are not. Try again. Once it is in the area you can reinsert the Dipstick this will allow you to feel for the hole if you let it go down past the bottom. once you find the hole (That you can't see) the dipstick will slide into it easily. Now you can raise the tube just high enough to clear the mounting stud on the valve cover.
I wrestled with this for about 2 hrs before I broke down and researched a solution. Then it took me an hr to figure out what to do. Hopefully this will save you some time.
Thanks to Motorcarman Bob I was able to get a good idea of where the end of the Tube needed to be.
Old Dec 15, 2013 | 06:34 AM
Originally Posted by DrkNyte
If you ever end up making the same mistake I did or by chance ever need to replace the tube it's not easy and I couldn't find any instructions on JTIS. ...............
Any chance you'll repeat the removal / install procedure to take some pics?
Old Dec 15, 2013 | 10:32 AM
MFoncerrada8's Avatar
Talking
Originally Posted by ggg
any chance you'll repeat the removal / install procedure to take some pics?
lol
Old May 15, 2015 | 10:12 AM
monster48's Avatar
Can I drive the car without the dipstick tube installed….Changed valve cover gasket and made the big mistake of removing the tube I have worked on it for several days…need help
Old May 15, 2015 | 10:13 AM
monster48's Avatar
2003 XKR Also a diagram of where the tube goes would be a big help
Old May 15, 2015 | 06:53 PM
wolfpck1's Avatar
no oil will blow out of the hole under pressure from the engine the dipstick on mine lines up with the second lower bolt coming from the front of the left side valve cover ...should be able to feel where it goes or use a mirror to see where you need to go to ... it pushes into the hole make sure you tighten the nut the goes over the valve cover bolt the bolt has a threaded stem coming off the top on my 99 xk8 .
Old Mar 27, 2017 | 12:38 AM
XK_SL's Avatar
Pulling up an ancient thread as I Went through this nightmare yesterday after taking the dipstick tube off during a power steering pump repair.
Read through this and the other threads and spent 4 hours fiddling around trying to get the blasted tube back in to no avail. In the end gave up and removed the bonnet (hood), took out the fans and moved the compressor out of the way. After that lot was done, barely took 2 minutes to guide it back in as you could see where it was supposed to be.
Old Mar 27, 2017 | 08:30 AM
JimmyL's Avatar
Red face Dipstick
I'll have to make a note of that. It's always the "little" things you don't think much about on disassembly that come back to bite you on assembly ! I feel for you monster. Good luck.
Old Mar 17, 2022 | 08:54 PM
oldjaglover's Avatar
Why did you remove the dipstick tube to do the PAS pump R&R? I'm doing that PITA job right now, and I'm having trouble even getting to the stupid clip on the back of the pump. I will NOT remove the tube for any reason. But how did you remove the tube from that hidden clip?
Ken
Old May 30, 2022 | 06:45 PM
stevepaa's Avatar
If I move the PAS pump can I get a view of the hole?
Old May 31, 2022 | 05:32 PM
stevepaa's Avatar
I moved the PDAS out a little which gave me all the room all the room I needed to locate the hole for the tube.
Old Apr 14, 2023 | 09:08 PM
tedgasthm's Avatar
If you put the borescope light in this area and close to the block you can find the hole with the camera.
Once you locate the hole with the cam you can hold the light on the hole and lower your head down to sight across the top of the fender toward the light and you can see the hole from that position.
I'll add my two cents here: I just made this mistake on my 2004 XK8 Convertible with the 4.2 and boy was I honked! However, I did learn a couple things that may help someone. Contrary to popular belief, I WAS ABLE TO SEE THE HOLE FROM ABOVE WITHOUT REMOVING ANYTHING. Here's how: I bummed a borescope with an LED light built into it and used that to locate the hole. It was the only shiny spot in that area. i was able to move the cam toward the shiny spot and verified that it was the dipstick hole. I was using the scope as a guide while fishing the tube into place when I realized that if I put my face down right where I could sight across the top of the fender toward the cam light I could see the shiny spot where the little light was concentrated! Once I knew where it was it helped tremendously in getting that sucker back in place. I will attach a couple of pics in the morning to give you the general idea. I also cut the eyelet hole in the dipstick bracket and curled the ends up to allow me to slip it sideways onto the stud without lifting the tube. The used the retention nut to pull the ends back down flat as I tightened it. Hope this helps someone else.
Old Apr 15, 2023 | 01:14 AM
Pistnbroke's Avatar
Borescope......sounds like an appropriate use of the well known auto term "a gynaecological job"
Old Apr 15, 2023 | 03:40 PM
Hell-Cat's Avatar
Might be easier to drop the engine oil pan and feed a wire coat hanger up through the dipstick hole, then use the upward protruding coat hanger to guide the dipstick tube in to place. You can also use that as an opportunity to fish out any chunks of chain guide.
Tip of the day: Drain the oil before dropping the oil pan....
Old Apr 15, 2023 | 08:12 PM
FYI: I did the PAS R&R a few months ago.....without removing the dipstick tube. I unscrewed the little bolt that holds the tab on the bracket and used it and a small zip tie to hold the tube in place while I did the PAS job.
nilanium
Nov 2, 2025 10:23 AM
mkrion
Nov 11, 2023 04:08 PM
MK2 1962
16
Oct 15, 2021 03:50 AM
crbass
Dec 3, 2020 08:01 AM
cdg66mk2
Oct 1, 2020 07:21 AM
