Engine & transmission removal??
Old Jul 8, 2012 | 05:10 PM
deelli's Avatar
Default Engine & transmission removal??
Need to remove the engine and transmission from my 97 XK8; need advice on how to remove them...should I remove the engine first or remove them as an assembly.
Old Jul 8, 2012 | 05:52 PM
Provided you have the facilities to cope with the weight, it's much easier and quicker to remove the engine and transmission as a unit.
Old Jul 8, 2012 | 08:50 PM
motorcarman's Avatar
The way we always did it at the dealer was to remove the front subframe, engine and gearbox as a unit. We had 2 rolling tables about 24" tall and lowered the car onto the tables to set the front suspension and powertrain. The engine and gearbox were separated and the tables rolled apart.
The engine was lifted and replaced. the tables rolled together and the car lowered to install.
Fastest and least damaging way I know how.
I have done this with 2 hydraulic tables but they are at the MAX weight capacity.
Hydraulic Lift Table - 500 Lb. Capacity
Without a lift you need to find alternate methods.
bob gauff
BrentGardner
29
Dec 16, 2024 12:13 AM
Woznaldo
Jan 31, 2016 03:22 AM
SatanClaus
US Southwest
Aug 31, 2015 11:45 AM
SatanClaus
Aug 29, 2015 09:15 AM
SingBlueSilver
Aug 27, 2015 02:20 PM
