engine warning light!!!
Old Mar 11, 2012 | 06:37 PM
SoBeHeat's Avatar
Default engine warning light!!!
the check gas cap message came on while driving, so i stopped and found gas cap secured ok. I took it off and put it back and continued on my journey, then the engine warning light came on???? car is running perfect, but the yellow engine picture is on speedo, what gives??? I am a new owner, 2001 XK8 w/ 33000 miles. HELP!!!
Old Mar 11, 2012 | 06:55 PM
The 'check gas cap message' on a 2001. Do you mean the low fuel level indicator that comes on when you're down to 10 litres (a little over 2.5 gallons)?
If the Check Engine light is on, get the codes read or it's just guesswork.
Old Mar 11, 2012 | 07:07 PM
SoBeHeat's Avatar
the message read "Check Gas Cap" and how do you get the codes??
Old Mar 11, 2012 | 07:23 PM
austinmartus's Avatar
The check gas cap is displayed when there is a leak in the evaporate system for the fuel tank. The check gas cap message is displayed because it is considered the most common fault by the factory. if you check codes there will be a evap leak code set, some common things are the canister close valve, leaking carbon canisters or leaking tube between the canisters, or leaking purge valve by the throttle. to check properly the canister close valve has to be commanded shut by a scanner or ids
Old Mar 11, 2012 | 07:25 PM
Hit post by accident.
Then use a evap smoke machine or pressure tester and the search for the leak. sometimes can be hard to find.
Old Mar 11, 2012 | 07:31 PM
If you haven't got access to a code reader then Autozone or similar will read them for you.
Write down exactly what the code or codes are and post them here.
Old Mar 11, 2012 | 08:31 PM
Beav's Avatar
It also doesn't preclude that the gas cap itself may be bad. Had tons of those at various dealers.
Old Mar 11, 2012 | 08:52 PM
SoBeHeat's Avatar
Thanks guys, I will have the codes checked and post them.
Old Mar 15, 2012 | 09:46 PM
SoBeHeat's Avatar
I had the codes checked and they read:
P0455 : EVAP EMISSION CONTROL SYSTEM LEAK (large)
P1000 : MANF CNTRL FUEL&AIR METERING, AUXILIARY EMISSION CONTROLS
I erased the codes, and the engine warning picture. I was driving again and the
"Check Gas Cap" alert popped up. I turned of the car and removed the gas cap, I tapped the gas cap against a wall and re-installed it. I have not had a problem yet.
I guess I need a new gas cap?
Old Mar 16, 2012 | 04:09 AM
Looks to be a good diagnosis.
P1000 : System checks not completed since last memory clear
P0455 : Evap (system) leak detected - large
The first P1000 is normal and will appear every time the codes are cleared until you've driven sufficent miles (or deliberately done 'drive cycles') to complete on-board monitoring tests. At this point it changes to P1111
P0455 possible causes range from the simple Fuel Cap off or Fuel Cap Seal defective through EVAP component physical damage or harness faults. The wall treatment points to the simplest - it's looking like the Cap.
Old Mar 16, 2012 | 10:56 AM
H20boy's Avatar
the evap system is one of those systems that just needs maintenance as the car ages, the canister close valve will stick open/close due to rust falling into it from the vent tube which is metal...its gonna happen. Gas cap is cheap to see if it fixes it, but if I were a wagering enthusiast, i'd put a chip or two on the CCV - vent tube combo. let us know how it goes please!
Shawn Svacha
Nov 4, 2019 02:47 PM
X_Type_South_Africa
Dec 9, 2015 05:37 PM
tberry6686
Sep 20, 2015 03:22 PM
Oliver9218
Sep 3, 2015 05:33 PM
Aranon
Sep 1, 2015 01:00 PM
