Error message. Restricted performance
Old Jul 16, 2014 | 03:42 PM
edwin761's Avatar
Default Error message. Restricted performance
My 1998 xk8 keeps coming up with an error message which restricts the revs to 3000 and the speed to 50 mph. In the morning it's fine but if I drive a few miles, stop for a while (10 mins) then restart the error message comes on. Sometimes it will go off after driving a while but it seems to be happening more often. Has anyone had the same problem and what can be the cause. The engine has just clocked up 100,000 miles. Regularly serviced.
Old Jul 16, 2014 | 05:55 PM
bleeth's Avatar
Hey Ed:
Check out my experience with this one and try my mechanics solution:
https://www.jaguarforums.com/forum/x...e-more-118942/
No guarantees but if it works it will be great.
Dave
Old Jul 17, 2014 | 12:08 PM
edwin761's Avatar
Default Restricted performance
Thank you for your advice. I have read through the thread and always use high octane fuel. The battery is now 2 years old but the problem has been since I bought the car 4 yrs ago. However will check the fuse because if I put the radio on for a while without starting the engine the error message comes on straight away and the car ticks over as if only 4 cylinders are firing. Thank you once again will keep you informed.
Old Jul 17, 2014 | 12:34 PM
giandanielxk8's Avatar
Get the codes read. It could be any number of faults. Come back with the OBDII codes so that we can better assess the problem.
Old Jul 17, 2014 | 02:00 PM
steeevo's Avatar
i had restricted performance and it was the throttle position sensor wiring circuit code. cleaned the contacts and the code went away. but yours could be anything if you don't know what codes its throwing up
jimforrest (uk)
Feb 28, 2019 06:42 PM
Delta66
Oct 4, 2015 05:40 PM
10 XF Premium
Oct 2, 2015 09:22 PM
Johncy2000
Oct 2, 2015 01:05 AM
Glenn Barickman
Oct 1, 2015 04:09 PM
