Exhaust & Intake?
Old Feb 24, 2010 | 06:46 PM
Miami XKR's Avatar
Miami XKR
Question Exhaust & Intake?
Hello,
New to the Jaguar forums.
I have a 06 XKR and i was trying to find the best exhaust and intake for it.
Any suggestions?
-Alex
Old Feb 24, 2010 | 07:38 PM
dfwx's Avatar
I'm a Jag newbie (05 XKR) but have been researching the heck out of this.
For intakes? I suggest just going to a K&N filter and leave it at that. The intakes that lay on top of the motor would show a slight power increase WITH THE HOOD UP, but otherwise likely a lose. If there is a GOOD intake that pulls from OUTSIDE then maybe.
Check out You Tube for "XKR exhaust." You can see and hear the different offerings. The "X PIPE" is probably the "best", but looks like they're about $3K!
I suspect they're all close on performance results.
A low dollar alternative? On eBay there is a set of bypasses for the rear mufflers/resonators that should give you a little volume and freer flow for around $400 with shipping - lowest cost.
Nothing says you can't just go to a muffler shop and have them straight-pipe eliminate a muffler or two. I'm looking at having an X-pipe (generic) to replace the forward muffler. Might put in electric cutoffs (about $400) to give me the choice between loud and quiet.
Good luck - and stick around this forum. Not a lot of people where but great info. Do some "searches" on the search feature for keywords like "XKR exhaust" etc, etc.
Do you have a coupe or 'vert?
Old Feb 24, 2010 | 08:07 PM
daddyo007's Avatar
Try Jaguar XP for exhaust choice. Its a place to start.
Also try the search tool on exhaust. Not too long ago some one posted some thing about exhausts. I'll see if I can find it if you can't.
Check out Quicksilver Exhausts at:
http://www.quicksilverexhausts.com/
Old Feb 24, 2010 | 09:13 PM
Miami XKR's Avatar
Miami XKR
I have a copper black covert Victory etd.
Do you know if the xkr will gain power if you do straight pipe from header back?
Old Feb 24, 2010 | 09:26 PM
Miami XKR's Avatar
Miami XKR
Actually this sounds good!
Mina exhaust, Performance Intake kit, Supercharger pulley all for $1115.oo!
Has anyone used these mods before? are they any good?
Old Feb 25, 2010 | 09:03 PM
K.Westra's Avatar
If you can afford it, the MacLeod X-Pipe is the one to get:
http://www.minagallery.com/jagxp/Jag...nce/X-pipe.htm
Here is what it sounds like:
http://www.youtube.com/watch?v=4PeqTzvkzWw
I'm probably going to end up with the standard Mina system, since it seems to be the most affordable, but I might look into a custom setup from an exhaust shop.
Old Feb 25, 2010 | 10:57 PM
GreenJewel's Avatar
I'm Nothing says you can't just go to a muffler shop and have them straight-pipe eliminate a muffler or two. I'm looking at having an X-pipe (generic) to replace the forward muffler. Might put in electric cutoffs (about $400) to give me the choice between loud and quiet.
Back in July I posted some pictures of my exhaust without the center muffler. Do a search for XK8 exhaust without center muffler as the title of the message.
Old Feb 26, 2010 | 11:39 AM
K.Westra's Avatar
Here is a direct link: https://www.jaguarforums.com/forum/s...ad.php?t=21246
Old Feb 26, 2010 | 05:56 PM
Brian2000XKR's Avatar
I have the MacLeod X-Pipes I, and they are music to my ears. The sound is head and shoulder over an OEM exhaust, and I have been more than satisfied with them. That being said, they do not add any MPG's that I can ascertain. As far as improved HP's, I can't feel any difference in acceleration, although that is very subjective. The look is great though, and the sound is phenominal!
Brian
Old Feb 26, 2010 | 08:07 PM
Miami XKR's Avatar
Miami XKR
Any opinions on the MINA exhaust?
Old Feb 26, 2010 | 11:46 PM
DaleD's Avatar
From: Marin County, CA, USA - Just north of San Francisco
Can you post any attachment that tells us what the sound INSIDE is - and if it is a coupe or a convert? Thanks DaleD
PS the sound outside sounds great! d
Old Feb 27, 2010 | 04:28 AM
Hi Dale,
Sorry, I don't have the means of recording the interior sound. I have a coupe, and (to me) it is the perfect blend of subtlety and aggressive roar. You hardly notice the exhaust noise from the inside...........until you put your foot into it, and then it positively comes alive! I can't tell you how many people have commented on how nice it sounds from their perspective as I merely drive away. As I said in other related threads, I couldn't be happier with the look and the sound! Damn, I love that car!
Regards,
Brian
Old Feb 27, 2010 | 07:33 AM
Jaxkr's Avatar
I agree with Brian your best bet is the MacLeod exhaust system, they have dynoed that exhaust & have seen app 20hp increase. The Mina system is more cosmetic. As far as intake you want a cold air intake, not something that draws in hot air from under the hood.
You need to make something like this, it does not have to be this crazy but you see the idea as the filter is in the front wheel well. The Mina system will give you noise but no power increase, more mlikely in warm weather when starting less because of the heat.
Old Feb 27, 2010 | 11:59 AM
SeismicGuy's Avatar
Hey JAXKR--where did you get all the chromed/polished/carbonfiber appearance goodies?
Doug
Old Feb 27, 2010 | 01:43 PM
Jaxkr's Avatar
I am a member of XKEC & found the strut caps & air intake thru members of the forum. The air meter is a custom unit I had made here in the US thru Mass Airflow, the rest of the intake is a custom setup I made. The polishing on the factory parts as well as the custom items was done by a company local to me that specalize in metal polishing. The carbon is thru a company in the midwest VC Finnishes. Hope that helps.
Old Feb 27, 2010 | 01:49 PM
dfwx's Avatar
Wow, that is beautiful!
Old Feb 27, 2010 | 03:00 PM
Sweet!!!!!!!!!!
Old Feb 27, 2010 | 04:01 PM
SeismicGuy's Avatar
I particularly like the strut caps as these are somewhat subtle--it there some supplier of these that you can point us to?
Doug
Old Feb 28, 2010 | 02:20 AM
Miami XKR's Avatar
Miami XKR
JAXKR If you plan on selling any of your parts let me know.
I will buy them asap : )
Old Feb 28, 2010 | 06:32 AM
steve11's Avatar
ud
JAXKR - Very cool look. Stock enough to meet my tastes, yet real eye candy under the hood.
Is the air inlet tube insulated, or just tubular steel?
