Exhaust Rattle, or worse??
Old Apr 24, 2020 | 09:11 PM
David Moffat's Avatar
Default Exhaust Rattle, or worse??
Hi, I'm new to this forum and not particularly mechanical. My 96 XK8 has (130,000 kms) started to make a rattling noise from the rear of the car when its cruising along with revs between 1300 and 1600. When you press the accelerator the rattle begins and continues until either the transmission changes down or the revs climb to around 2000.
Is this likely to be a differential issue? or (fingers crossed) something less sinister.
Cheers Moff
Old Apr 25, 2020 | 06:03 AM
RJ237's Avatar
Look for loose heat insulation or exhaust hanger.
Old Apr 25, 2020 | 04:07 PM
Thanks, sounds like a good place to start. hopefully that's all it is.
Moff
Old Jul 31, 2022 | 04:11 AM
John202's Avatar
Default Rattle from rear.
Cheers Moff
can be perished shock absorber mounting .
Old Aug 1, 2022 | 01:43 AM
Pistnbroke's Avatar
Your transmission oil level is low and the pump/torque converter are complaining. I drained 3.6 l out of mine and put in 6.
Stop looking thats it.
jamesneely
Mar 21, 2021 12:52 PM
GordoCatCar
Jan 23, 2018 02:10 PM
yycjaguarftype
Jun 29, 2017 01:29 PM
ukdude
Mar 7, 2015 07:38 AM
