Exhaust smells rich
Old Mar 29, 2013 | 01:15 AM
jlfloerke's Avatar
Default Exhaust smells rich
Hello, i've noticed that my 2000 xk8's exhaust smells very rich. There is no check engine light, so I wonder is this a normal thing or should I look into changing plugs? The car has 92k miles if that helps
Old Mar 29, 2013 | 04:10 AM
jimgoose's Avatar
You shouldn't be able to get a noticeable odour of fuel from the exhaust. It is possible that it is not coming off cold-start enrichment map-tables (and back on Lambda) after cold-start, due possibly to a bad coolant temperature sender? You should have the codes read. How does it run when warmed up?
Old Mar 29, 2013 | 05:06 AM
jlfloerke's Avatar
The cars runs perfect but after the odor remains after warm-up. I just purchased the car recently and the first thing I did was clean out the part load breather which was clogged, there was oil in the intake from this. Is it possible that the cats are clogged from the previous owner driving the car with the oil intrusion? Also would there be codes without the check engine light on?
Old Mar 29, 2013 | 05:30 AM
jimgoose's Avatar
Yes, you can have DTC codes without the MIL light showing.
Old Mar 29, 2013 | 06:53 AM
jimgoose's Avatar
It's hard to say how the cats are - it depends on how much oil was being burnt while that breather was blocked. Regardless, that shouldn't result in a smell of fuel, I wouldn't have thought.
Old Mar 29, 2013 | 08:21 AM
Brutal's Avatar
Its a Jag! Not only does it smell Rich, it makes you look RICH too!
seriously though, close to 100k change the plugs and do a hard battery reset. oil in the intake is normal. clean fuel injection system and throttle body, other than that be happy and dont over think the car
Old Mar 29, 2013 | 11:10 AM
mike66's Avatar
[QUOTE=Brutal;706530]Its a Jag! Not only does it smell Rich, it makes you look RICH too!
I'm glad I wasn't the only smart-*** to think that..........How's your gas milage?
Old Mar 29, 2013 | 03:12 PM
jlfloerke's Avatar
I mainly drive this car to work and back on the interstate doing about 80mph for 45mins twice a week and it has been averaging 25.6 mpg. I'll get some new plugs and clean the throttle body. Also i'll have to go get a code reader at autozone unless someone recommends a particular code reader
Old Mar 29, 2013 | 04:30 PM
mike66's Avatar
Good milage. Enjoy!
boiler
US Southwest
Dec 20, 2025 12:38 AM
NathanDD6
Oct 6, 2015 11:20 AM
baskervillema
Oct 1, 2015 06:43 PM
Glenn Barickman
Oct 1, 2015 04:09 PM
