Exterior door handle gasket.
Old Aug 31, 2013 | 10:26 AM
philhef's Avatar
Default Exterior door handle gasket.
While working on my rub strip removal, I noticed the exterior door handle gasket was crumbling. I'm not sure what to do. Is this common? Looks like a real pain to replace if even available. I actually thought about removing the rest of it and running a line of black silicone caulk in it. Neatly of course!
Any advise? I don't want water leaking in.
Old Aug 31, 2013 | 10:38 AM
Jag#4's Avatar
You can buy the gaskets for about $40 USD each. They do come separately (left and right sides).
Here's a thread on your question. Replacement does require removing the door card.
https://www.jaguarforums.com/forum/x...gaskets-50908/
Old Aug 31, 2013 | 12:37 PM
I got mine through Jagbits for ~$100 for the set. It is a bit of a pain to replace unless you have help. I replaced mine and trying to tighten the 2 bolts while making sure the gasket and handle were seated properly were a bit of a trick but overall about an hours worth of work.
Here's the link for the gaskets
http://www.jagbits.com/mm5/merchant....LM12035-GASKET
Old Aug 31, 2013 | 03:27 PM
Beav's Avatar
I just used a sharp knife and trimmed the crumbling bead, using care not to scratch the paint underneath. Takes about a minute and the sealing portion of the gasket remains functional.
Dz1rfj
Jul 17, 2018 10:29 AM
Dz1rfj
Sep 16, 2015 03:44 PM
sadepol01
Sep 11, 2015 05:26 AM
1964Daimler
Sep 9, 2015 11:28 AM
hoodun
Sep 7, 2015 07:02 PM
