Is this a failed upper shock mount?
Old Sep 15, 2022 | 05:18 PM
Texasbill's Avatar
Default Is this a failed upper shock mount?
I just replaced these less than 3 years ago. Does the fact that the strut threaded rod is offset indicate a failure? If so, what would cause this so fast? Also, where can I buy a good one?
Old Sep 15, 2022 | 06:21 PM
STLTHMSTA's Avatar
Juat wait, the replies will be coming. Yes, that is the beginning of segregation of your upper mount. Many replacements are disappointing to say the least. Forum member Wayne is making replacements. Not sure how many requests he can keep up with so I won't answer that. I have used the Uro brand that many don't like but mine are good so far. 2 years or so. TM
Old Sep 15, 2022 | 06:38 PM
baxtor's Avatar
Yes, it is failing but with a twist.
The material used looks like it is polyurethane and not degrading as the foam ones do. However moving off centre still results in a mount that no longer works.
In my opinion it is caused by a design fault in that the bushing is not restricted enough in it's lateral movement. This has been addressed.
Suggest you contact Wayne if you are in the USA
Old Sep 16, 2022 | 12:50 AM
Kuddlesworth's Avatar
You have rat poo on you're strut as well.
rackets351
Jan 20, 2021 07:46 PM
wymjym
Feb 10, 2020 10:51 AM
apexjag
Sep 24, 2019 12:52 AM
funracer
Jul 8, 2019 06:49 PM
Rezzz
Jan 19, 2014 06:55 AM
