Fault messages on a 97 XK8
Old Oct 19, 2016 | 07:25 AM
FLYINGFOX4475's Avatar
Default Fault messages on a 97 XK8
Hello all , as a new member I have my first problem to report . I have owned my 97 XK8 coupe and use it as a weekend fun car with the occasional commute , current mileage shows 95000. Up until recently there have been no issues with the car and it has performed very well in all aspects, however ,m I am now getting two fault messages , firstly an intermittant "Gearbox overheating" which has appeared occasionally at random over the last month or so . Secondly , and over the last couple of weeks a "Suspension fault" message which first appeared when I had to brake suddenly but now wont go away . I have tried disconnecting the battery for a couple of days and I have checked all of the connections that I can get to easily but to no avail . My questions are , could these two message events be connected and, regarding the suspension message , my car has the optional CATS suspension , If I disconnect the module in the boot(trunk) will this rid me of the message? (I understand that the shocks will default to firm on disconnection)Any thoughts , suggestions or advice most welcome . Thanks in advance
Old Oct 19, 2016 | 07:45 AM
Glyn,
I've moved this question from your Intro thread to XK8/XKR forum. Members here with the same model will be able to help.
Old Oct 19, 2016 | 01:05 PM
Pristine97XK8Convertible's Avatar
I'm not familiar with the faults you mentioned. In any case, pull the OBD codes and let members here help you out.
Old Oct 19, 2016 | 04:07 PM
RJ237's Avatar
Yes, try unplugging the module.
Digital Will
Feb 21, 2026 05:58 PM
sg18438
Oct 16, 2016 05:04 PM
97 Xk8 mayhem
Oct 8, 2016 01:27 AM
Rogerdavis
Oct 4, 2016 11:39 AM
relinuca
Nov 11, 2010 11:31 AM
