Fitting a Parrot Asteroid device to my XKR
Old Feb 18, 2016 | 01:48 PM
WhiteXKR's Avatar
Make sure the MUTE function is enabled as follows:
Enter setup mode as follows:
-Press the TAPE EJECT and AM/FM buttons simultaneously.
-Now press PRESET 4 button repeatedly until 'TEL ON' shows
-After 15 seconds the display should clear and hopefully the mute will now work.
Mute can be tested by grounding the mute pin.
Old Feb 18, 2016 | 04:00 PM
Rocky15's Avatar
WhiteXKR
I tried what you said but the phone func was already on.
Also I noticed my aerial doesn't work and also nothing on the satnav screen.
Any ideas, all fuses in the boot are ok
Old Feb 18, 2016 | 06:31 PM
Rocky15's Avatar
Hi Still can't get the mute to work. I noticed there's a mute output from the radio to the amp. Do you think I could disconnect from the radio and take it to the parrot?
Old Feb 7, 2018 | 06:47 AM
PaddyLondon's Avatar
Default Progress?
Rocky,
Did you succeed? I started looking at this six years ago with help from White XKR and StevePaa (who very kindly gave me a connector to join the RT connectors in the boot together). Unforturnately, my Radio Telephone (RT..) connectors were corroded and not usable, with blown fuses etc. After a six year delay, I've got them operational and the phone bit of the puzzle works for me - plug and play with a Nokia CK300..
To connect to the 10 pin connector under the armrest I used "Autoleads Cellular Interface Lead PC6-101", which makes the telephony bit more simple. I'm using
JAG-CDR Auxiliary Jack, Changer retention Kit for Select Jaguar XJ and XK :: iPod Adapters & Interfaces to create an Aux connection or relay of stereo output to the factory system, either wired or via bluetooth adaptor.
Old Feb 7, 2018 | 06:52 AM
Default Lead in question
This is the lead... If you cannot find one, I have a slightly butchered one... Works for MY2000
Old Feb 8, 2018 | 07:54 AM
Rocky15's Avatar
Hi
Many thanks
I did actually succeed with this project. The problem I had was a very simple one but yet very fustrating.
I had to purchase a spare head unit to eliminate it and then coming to remove my original one I discovered that the yellow connector was not fully plugged into the radio.
It was such a simple problem I created from being careful and once plugged in all the way everything started working.
Thanks for asking
RickyJay52
Dec 25, 2019 11:56 AM
RobbyHughes
Mar 8, 2016 07:46 AM
kulddy
Dec 31, 2015 12:25 AM
Goncalo Proenca
Dec 17, 2015 01:39 PM
blindside
Dec 12, 2015 04:48 AM
