front camber adlustment question
Old Apr 29, 2026 | 03:53 PM
Pantera928's Avatar
Default front camber adlustment question
I have gotten conflicting stories so I will ask here.
The front camber is adjusted by bolts on the inner lower control arm. Some have said that only the front bolt on that arm has a camber adjustment bolt and others have said that both inner bushings on the lower control arm should have the special bolts for camber adjustment.
It seems that if it is just the front bushing bolt, then the caster would be affected.
FYI, the guy at the alignment shop thought it was the long bolt for the upper arm bushing that made this adjustment but when he turned it, of course nothing changed.
Even the diagram on his machine showed that it was the upper bushing bolt.
This happened at two different shops
Old Apr 29, 2026 | 04:33 PM
baxtor's Avatar
Only the rearward (adjacent to steering rack) of the lower arm bolts MAY be of the eccentric type. Not all were fitted with these eccentric bolts. The forward position is a plain bolt only.
caster is controlled at the upper control arm fulcrum bolt by way of shims. Turning this bolt will do nothing.
Old Apr 29, 2026 | 05:47 PM
motorcarman's Avatar
The ECCENTRIC bolt was the subject of a TSB and listed in the JEPC as ECCENTRIC SHANK BOLT JZB1000086-Refer to dealer support for fitment information.
I remember the TSB but I don't remember the document number or what the exact model or category was.(Parts, Admin, X100?)
If I remember or find it, I will post the info.
I think I had them at one time for an alignment job but not sure. (decades ago)
sanchez
May 8, 2019 07:45 PM
Lannyl81
Mar 27, 2017 12:14 PM
dneu
Aug 6, 2012 09:49 PM
Skid Mark
Dec 24, 2011 02:30 PM
theusualsuspect
Apr 15, 2011 05:17 PM
