Front Driver's Side Is Low
Old Jan 4, 2016 | 10:30 PM
skubeedoo's Avatar
Default Front Driver's Side Is Low
I've got a 1998 XK8 and the front driver's side only has a gap of about one inch between the top of the tire and the wheel fender. The right side is about two inches. Whenever I make a hard right turn, the left front wheel rubs on the fender. If I hit a dip, the left tire rubs on the fender. What could the issue be? Bad shock/strut?
Thanks in advance
Old Jan 5, 2016 | 04:29 AM
jamdmyers's Avatar
Springs, Upper Shock Mount, Shock, do a search on mount and u will find how to replace them, if urs haven't been changed they probably need it.
Old Jan 5, 2016 | 01:35 PM
Johnken's Avatar
Jamdmyers, if you decide to tackle the job email me for some pointers. I relearned way too much when i did mine last weekend. Guess i forgot lots of fine points ths reallt add up to time savings. Be glad to share.
Old Jan 5, 2016 | 02:55 PM
RJ237's Avatar
New shock mounts and spring isolators will make a big difference, but will not compensate for a sagging spring.
You can add a spacer up to 3/8" thick between the shock mount and the seat. I made one from a plastic cutting cutting board.
Old Jan 5, 2016 | 03:33 PM
brgjag's Avatar
sounds like you have a spring that is out of spring. My 03 sat like that on both sides. I did springs and the upper and lower bushings. But the combo of a new spring and upper mount most likely will fix it. Bigger question is should you do both sides though one seems good. Spending your money for you, I would do both sides, all of it if you are keeping the car long term.
Old Jan 6, 2016 | 03:32 AM
jamdmyers's Avatar
Thank you, I'd done these 2 years ago but actually going through it again this winter with new shocks / springs! all parts arrived yesterday so it will be a busy week!
Old Jan 6, 2016 | 10:08 AM
Johnken's Avatar
Remember to insert shocks into new springs before you start compression. I didnt and had to undo then start all over. They will not fit with spring compressors compressed.
Carefully align shock bolt hole with shock mount protruding bolts while compressed -can't be moved after release.
Old Jan 7, 2016 | 11:46 AM
skubeedoo's Avatar
Where do you buy your components? Any special brand?
Old Jan 8, 2016 | 02:22 PM
Johnken's Avatar
I went to partsgeek for everything except springs. Went to Guadin for them. Quiz them on a delivery date b4 you sign the check, do not order on line - call them and quiz them.
Old Jan 9, 2016 | 02:19 PM
Jag#4's Avatar
Jagbits had a better price for the springs when I bought mine last month. They are a forum sponsor and offer discounts if you mention the forum.
Quicktruck
Jul 29, 2016 10:45 PM
fox5mx101
Dec 25, 2015 06:34 AM
kamalislamof
Dec 22, 2015 06:10 PM
tat2ist
Dec 20, 2015 12:33 PM
Qgregg
Dec 20, 2015 10:55 AM
