Front lower wishbone ball joints
Old Jan 2, 2022 | 04:56 PM
szhilian39's Avatar
Default Front lower wishbone ball joints
I would like to replace these two ball joints and was able to find the part number for the blue one (JLM21380). Does anyone know the part number for the red one?
I 've read multiple members replaced their ball joints (red), but I only found a whole arm assembly (#6 in the diagram), not the ball joint part number.
Thanks in advance.
Old Jan 2, 2022 | 05:33 PM
NorXKR's Avatar
Lower balljoint is MNC1350AA. PITA to replace, but it can be done.
Old Jan 2, 2022 | 06:25 PM
cjd777's Avatar
This thread my give you the answers.
https://www.jaguarforums.com/forum/x...joints-109703/
Old Jan 2, 2022 | 06:34 PM
szhilian39's Avatar
Thank, I appreciate it.
Old Jan 2, 2022 | 06:35 PM
szhilian39's Avatar
Now, I need to figure out how to press in the ball joint. Looks quite difficult.
Old Jan 3, 2022 | 06:51 AM
20ton hydraulic press, a 4x4 under the tapered edge of the control arm and patience
Old Jan 3, 2022 | 07:56 AM
szhilian39's Avatar
I found this thread and now understand what you meant.
https://www.jaguarforums.com/forum/x...4/#post1396395
Great info! Thanks!
Old Jan 3, 2022 | 11:29 AM
STLTHMSTA's Avatar
I did mine at home and had to get rather creative. I do have a press but the "fixtures" were the difficult part to come up with. TM
Old Jan 3, 2022 | 11:47 AM
szhilian39's Avatar
Does it have to be 20 ton? Harbor Freight has a 12 ton press, which I'm considering to buy.
Thanks!
Old Jan 3, 2022 | 01:46 PM
I tried a 10ton at the base hobby shop and had no luck, so opted for the harbor Freight 20ton. It could have very easily been operator error - don't know but it is a pain in the ****!!!
Old Jan 3, 2022 | 04:13 PM
michaelh's Avatar
Thanks!
IIRC it took around 8 tons to get them fully home, but ymmv.
Put the joints in the freezer for a day or so beforehand, and anything you can do to heat the control arm end will do no harm, either.
Good luck!
Old Jan 4, 2022 | 06:58 AM
STLTHMSTA's Avatar
Thanks!
Mine is a 12 ton harbor Freight special and worked fine. It's the fixturing that need to be right. I wish I had bought the 20 ton only because it's wider and allows bigger things to fit in it.
Again, ymmv, TM
cobrawet2
Mark V - X 420G
Jun 23, 2018 03:03 PM
rocklandjag
May 19, 2014 11:17 PM
talashek
Apr 24, 2013 11:41 AM
Jag XJ8 Red
Dec 8, 2012 05:08 PM
