Front Pass Seatbelt Replacement
Old Aug 23, 2020 | 12:18 PM
risctaker's Avatar
Default Front Pass Seatbelt Replacement
Greetings members. There is probably a wealth of information on this topic on this forum but since I must make a certain amount of qualifying posts in order to be able to download any of the service manuals, etc. I figure I would burn a post asking this:
The front passenger side seat belt assembly has exploded while on the watch of the PO and only the internal metal vestiges remain. The entire exterior plastic outer shell components are MIA.Can new exterior components be purchased and mated to the internals that remain or does the entire assembly have to be removed from the car and replaced in its entirety? If so does the entire passenger seat have to be removed first? Thanks.
Old Aug 23, 2020 | 12:37 PM
avern1's Avatar
I am not sure which element your considering replacing. Removing the seat will simplify any work you need to do. The removal is fairly easy to accomplish.
Below is a blow up of the seat belt parts diagrams. If you need advice for removal let me know.
https://www.sngbarratt.com/English/#...assembly/10347
Below is a link where you can download a free online parts catalog.
https://www.sngbarratt.com/us/#!/English/Downloads
Below is a link to follow for downloading a PDF shop manual. Just scroll down the page until you come to the heading WORKSHOP MANUALS.
\https://www.jaguarforums.com/forum/x...ts-data-29800/
Old Aug 23, 2020 | 05:31 PM
risctaker's Avatar
Thanks for the reply and good info, Vern.I have to wait to get my 10 posts as a newbie in order to access those referenced manuals but will do as soon as I can.
Old Aug 23, 2020 | 07:53 PM
avern1's Avatar
The links to SNG Barratt should be direct clicks. If you need the tech manual send me Private Message with your email address and I will send a link to my dropbox and you can download it there.
Sayed Ali Alqatari
Dec 19, 2019 02:41 PM
Greggbhill
Jul 15, 2019 04:09 PM
uncle jim
Oct 10, 2016 09:23 AM
vandenplas408
Mar 18, 2014 10:54 PM
Lawrence
XJ40 ( XJ81 )
Oct 10, 2012 04:26 AM
