Front shocks off center
Old Sep 2, 2025 | 09:10 AM
Bob Boyle's Avatar
Default Front shocks off center
I think this is a common issue. Does anyone have an idea on how to correct the problem permeantly. I the upper shock mounts about 5k miles ago as the originals had turned to dust. When I remounted them the shocks were centered and torqued. Now they are off center and the front suspension has become noisy. Any guidance would be appreciated. Passenger's side.
Passenger side.
Driver's side.
Old Sep 2, 2025 | 09:59 AM
zray's Avatar
The ones you put in are shot,
there’s a member here ( Wayne AKA @cjd777 ) who makes the top shock mounts that will last longer than you or your car. Contact him.
Z
Old Sep 2, 2025 | 11:55 PM
baxtor's Avatar
Passenger side.
Driver's side.
You got about 5k more than some out of them. 25mm hole in bottom of mount, 15mm damper shaft, you've got about 5mm to play with before metal to metal contact which will be the noisy suspension you hear.
As mentioned, Wayne can rebuild for you or l have kit for DIY.
Old Sep 3, 2025 | 08:13 PM
brinny's Avatar
Get the kit you won't regret it . This subject is well documented.
pcolapacker
Jun 5, 2024 08:26 PM
MLM22
Sep 2, 2020 05:52 PM
joelsjag
Jan 7, 2017 09:14 PM
oldjaglover
Oct 28, 2011 01:27 AM
Danster
Aug 25, 2010 07:44 AM
