Frustration !
Old Jul 3, 2013 | 01:11 PM
DevonDavid's Avatar
Default Frustration !
One of the very few problems (I hope) with my "new" XK8 is that the centre console won't shut properly - I suspect because a previous owner took it to bits and didn't reassemble it properly. I think the lid is OK, so it's the "bottom bit" that's causing the problem and I have tried every which way and can't get it to work properly.
There's basically three bits - the "top bit" and it's pretty obvious where that goes, and then two other bits, one with just a slot, and the second with the moulded plastic latch "tongue". There are two self-tappers which go through all three bits into the metal screw-plates and the lining is sandwiched in there somewhere as well. From the pictures, can anyone give me the correct order please - e.g. top, lining, 1,2 or top, 1, lining, 2 or ................ I'm sure you get the idea
It's driving me mad - it MUST be simple but I just can't figure it out !!
Thanks - as always.
Cheers,
David.
Old Jul 3, 2013 | 01:22 PM
panastas's Avatar
My armrest shuts fine and I don't have the bit labeled "2".
If i recall it goes "1", lining, top.
Good luck
Pavlos
Old Jul 3, 2013 | 01:42 PM
DaveC's Avatar
Agree with Pavlos. Just did the repair. I also don't have item #2 and it works fine.
Dave
Old Jul 3, 2013 | 02:32 PM
SteveJacks's Avatar
Attachment 47062
Attachment 47063
Attachment 47064
Thanks - as always.
Cheers,
David.
2 goes over 1, and 1 faces with the curled over piece toward the front of the car. That all goes under the trim peice you show in the middle pic (the piece missing from the first pic). These bits all go on after the lining is in place. Also, when installing, keep the screws slightly lose, so when you close the lid, the latch will move the pieces into their proper fine adjustment. Lift the lid, snug the screws, test. If it almost latches, or the lid can come up without pressing the release but you feel it catch slightly, then loosen the screws just a little, push the pieces toward the front of the car, snug the screws again and test. Be careful not to push these too far forward, as the latch wont release and you will be asking how to get the lid up. I tried to post a pic of mine, but the iPad camera isn't that good.
Old Jul 4, 2013 | 05:14 AM
DevonDavid's Avatar
Default Resolved
Thanks Guys - all sorted but ................... very odd. Steve - I tried your way but with both 1 & 2 pieces under the lining, the lining was too far up. So ............ got rid of piece 2, put it back together with the lining sandwiched between the top piece and piece 1, and it works O.K. so thanks Panastas & Dave C.
I'm quite used to doing a complicated job - brain surgery or fixing a laser guided weapons system and having a few bits left over, but repairing something that originally had three parts and only using two of them to make it work is a new one for me !
Old Jul 4, 2013 | 10:44 AM
DaveC's Avatar
You will soon have a box labeled "Jag Parts" for your leftovers and extras! There probably isn't anyone on this Forum that doesn't have one.
wilco40
Sep 24, 2015 08:26 PM
Vincentbrough
Sep 24, 2015 01:12 PM
Terry007
Sep 24, 2015 10:36 AM
wilco40
Sep 21, 2015 08:38 PM
jerry_hoback
XJ40 ( XJ81 )
Sep 13, 2015 07:48 PM
