fuel delivery problem
Old Aug 11, 2016 | 10:32 PM
dneu's Avatar
Default fuel delivery problem
My 1999 xk8 suddenly will not start. problem is a fuel delivery. A fuel pump does not run when key is turned on nor when cranking. I have dug out a fuek pump, but it is working. Wires from the connector in the right upper corner of the trunk have continuity. But when I pull out a fuel pmp relay and bridge terminals 3 and 5 the pump does not ryn. Should I have a constant 12V on the terminal 5? Where I should look for a breakege? Should I just run a new wire from the battery to the terminal 3 of the fuel pump relay? Please advice.
Old Aug 12, 2016 | 07:12 AM
Gus's Avatar
Gus
You have 2 sets of fuses for the pump one on start and another when it is running. See if this helps.
Link. http://www.jagrepair.com/FuelPumpVoltageChecks.htm
Gus
www.jagrepair.com
Old Aug 16, 2016 | 11:33 AM
dneu's Avatar
I found the problem, but it does not help much. The fuel pump was replaced about a yaer and half ago with the aftermarket substitute. This pump must be drawing much more amps because the multiwire terminal just behind the tank cover was almost welded together. I cut the power wires from it and conncted themwith the bullet terminals outside of the factory harness. But when the pump is running even the ground wires in the terminal are getting hot as well as the connecter the fuel vapor recirculation fixture on the top of the tank. I have ordered an original pump and will see whether there will be any difference.
dinop
Jun 14, 2016 02:48 PM
Navyflyer
XJ40 ( XJ81 )
Apr 15, 2016 09:57 AM
xkeots
Mar 31, 2016 02:03 AM
chprman
May 1, 2008 05:23 PM
Jan 26, 2007 11:13 PM
