Fuel Injection Relay Removal
Old Sep 12, 2014 | 03:55 PM
jimmiejag's Avatar
Default Fuel Injection Relay Removal
I've read here on the forum that the best way to crank the engine over to get some oil pressure back into the engine without starting it up after after replacing the secondary tensioners (yes, I had the 1st generation tensioners and both were cracked from the notch up along the length of the body: near catastrophe avoided!) is to remove the fuel injection relay. Correct?
I see the location of the relay from the 1999 XK8 Electrical manual is in the engine compartment, right hand side for my LHD car, near the scuttle (firewall.) But I can't figure out how to remove it. I don't want to try to pull the black plastic cover off and break it if there is some other way to remove the relay.
Help.
Old Sep 12, 2014 | 06:28 PM
cjd777's Avatar
Jim, if you have a pair of spark plug wire pullers, grab the relay on two opposite corners and rock it out. They generally have rubber covered tips.
Wayne
Old Sep 12, 2014 | 06:54 PM
test point's Avatar
Just rocking it out with your fingers usually works.
Old Sep 12, 2014 | 07:11 PM
RJ237's Avatar
Or pull the injector fuse, #5 in the engine compartment fuse box, passenger side.
dsnyder586
Dec 29, 2024 07:39 PM
redrover41
23
Sep 25, 2015 01:33 PM
leep123
Sep 12, 2015 06:53 PM
AL NZ
Sep 4, 2015 08:39 PM
XJsc-guy
Sep 2, 2015 11:43 AM
