Fuel Pump Location?
Old Aug 13, 2014 | 10:03 PM
jimmiejag's Avatar
Default Fuel Pump Location?
Where is the fuel pump fuse located on a 1999 Jaguar XK8 coupe? I need to pull that fuse so I can prime the engine with oil after a tensioner replacement job by spinning the starter.
Thanks.
Old Aug 13, 2014 | 10:09 PM
WhiteXKR's Avatar
Thanks.
Pull the fuel injection fuse instead..residual system pressure can cause a brief start otherwise. It is #5 in the Engine Managment fusebox (US Passenger side, under hood, next to windshield, in ECU compartment...NOT the fusebox under the hood on US driver's side).
Old Aug 14, 2014 | 08:48 AM
motorcarman's Avatar
I usually 'jump' the starter relay (30/87 or 3/5) so the key is not turned 'ON" with a fuse or relay unplugged causing a DTC in a module.
If you can read and clear a DTC with a 'scanner' then pulling fuses and cranking with the key is OK.
bob gauff
Old Aug 14, 2014 | 11:02 AM
blindside's Avatar
OR, you can just turn the car over after you put the cam covers on but before you install the coils... it worked fine for me.
AND, I also pre-primed the tensioners by putting oil into the "holes" while squeezing the tensioners a couple of times.
dsnyder586
Dec 29, 2024 07:39 PM
Sprayall
May 30, 2021 08:13 AM
ccfulton
Sep 20, 2015 05:15 PM
Kmw
Sep 8, 2015 04:52 PM
Sprayall
Sep 3, 2015 07:49 PM
