fuel sending unit
besides myself.......... i was looking at some old threads and the sending unit was replaced through the rear speaker .... but i have a convertible is there any way to go through the rear inside the car to replace the sender ???? tony
I replaced my sending unit from the trunk.
Instructions can be found at
JagRepair.com - Jaguar Repair Information Resource
If you are talking about the fuel pump replacement on a convertible, check out this link to a forum post about getting access without removing the tank
https://www.jaguarforums.com/forum/x...access-118362/
i seen that also but my access to the pump/sender is on top of the tank and the tank needs to come forward about 6 to 8 inch. to get to.. trying to think of a way to do it with out taking the gas tank out... but i don't think it's going to happen tks tony
Check out the post on fuel pump access-you may be able to access the sender unit the same way...it involves cutting through the metal, but it saves you from having to move the tank
jagent
Sep 12, 2015 09:10 AM
