Fuel trims
Old Mar 16, 2017 | 08:39 PM
Dale Dunn's Avatar
Default Fuel trims
I have read up on this but still looking for the wonderful advice I get here. Checked my fuel trims today and bank 1 is about 8 positive and bank 2 is about 24 positive. Also I get a really rough idle but throwing no codes. Any ideas??
Old Mar 17, 2017 | 04:23 AM
JagV8's Avatar
Hot engine, parked. If you get those at idle, rev to about 2500 and see what happens. If either drops much (well, the 8 is only a bit out) then you would expect an air leak.
Old Mar 17, 2017 | 10:13 AM
Dale Dunn's Avatar
Checked fuel trims again this morning. At normal operating temp at idle bank 1 reads +4-8%. Bank 2 reads +24%. At 2500rpm both go close to zero. Now, to find leak
Old Mar 17, 2017 | 11:00 AM
RJ237's Avatar
Since it's only bank two the intake manifold an gaskets is a good place to start.
Old Mar 17, 2017 | 11:05 AM
Dale Dunn's Avatar
That's what I'm thinking. Thanks
Old Mar 17, 2017 | 06:08 PM
Om28v's Avatar
Get valley hoses as long as your going in.
Old Mar 17, 2017 | 06:35 PM
Dale Dunn's Avatar
I recently did all that. Water pump, housing, and all hoses and new intake gaskets( bet I screw up somewhere)
Old Mar 17, 2017 | 07:46 PM
RJ237's Avatar
Always the place to look for trouble is something I fixed.
Old Mar 17, 2017 | 08:26 PM
Dale Dunn's Avatar
Yeah, me too. Got quite a bit in front of me. Have whitexkr's gauge set on order along with oil pan gasket and transmission filter, gasket, and new transflo pressure valve. While I'm waiting I'll go back and find my intake leak
Old Mar 18, 2017 | 09:21 AM
Brutal's Avatar
Mass air flow sensor, part load breather, cam cover leak, missing oring on oil dipstick. cracks in air intake tube or full load breather. Just monitor your full trims and spray areas with carb/brake cleaner when they start pulling you've found a leak. past this I would say your injectors have a crappy spray pattern. I would pull them(easy) and send them off for rebuild, cleaning and flow testing like to www.injectorx.com
Old Mar 18, 2017 | 04:34 PM
Dale Dunn's Avatar
Brutal, you hit the nail on the head. MAF sensor was dirty. I cleaned and worked fine. Thanks
Old Mar 18, 2017 | 08:03 PM
Gus's Avatar
Gus
This should be the first post on every Fuel Trim problem! We miss you Brutal!!
