full load breather - no orifice on 03XKR?
Old May 9, 2011 | 07:52 AM
deadboy1977's Avatar
Default full load breather - no orifice on 03XKR?
I was doing the throttle body and full load breather cleaning as described here on the forums for the 2000 XKR....when I removed the full load breather connections, there was no orifice on the valve cover side?? Is this the case for a 03 or was it removed or???
Old May 9, 2011 | 01:54 PM
Paul Pavlik's Avatar
The Full Load Breather does not have a Orifice. The Part Load Breather has a 3/32" Orifice.
Old May 9, 2011 | 02:02 PM
ok where is the part load breather?
the drivers side nipple that sticks out of the valve cover towards the radiator (front) must be part of the full load assembly?
Old May 9, 2011 | 02:43 PM
well i checked both sides of the valve covers, no orifice
you sure the 2003 has one?
Old May 9, 2011 | 03:30 PM
The Part Load Breather (near the front of the left cam cover) has a 3/32" orifice.
Old May 9, 2011 | 03:54 PM
test point's Avatar
Yes, it has an orifice but it is about an inch and a quarter down inside the nipple. I did the same thing.
Old May 9, 2011 | 03:55 PM
Goldlion's Avatar
Clicked a few pics of the PLB on my 2005 XKR.
Hope this will be helpful.
Tim V.
Attached Thumbnails full load breather - no orifice on 03XKR?-xkr-plb-001.jpg   full load breather - no orifice on 03XKR?-xkr-plb-003.jpg   full load breather - no orifice on 03XKR?-xkr-plb-004.jpg
Old May 9, 2011 | 04:59 PM
cpm53's Avatar
I have a PLB on my `03 XKR as pictured in the above post....
Old May 9, 2011 | 07:19 PM
well mine is wide open like 1.4 inch then you see the breather hose
i see no orifice, used a flashlight n all
it looks like the photos posted.
Old May 9, 2011 | 07:54 PM
test point's Avatar
On the left hand side cam cover the part load breather nipple includes a 3/32" orifice that is located about 1.25" down inside from the top of the connector. If yours does not have that you will have to replace the engine.
Either your orifice is completely clogged up or I hope this is a communications problem!
Old May 9, 2011 | 08:07 PM
Goldlion's Avatar
Well, here is another shot of the PLB on my 2005 XKR. The view is just about straight down. I have never had a problem with this part or engine performance.
Attached Thumbnails full load breather - no orifice on 03XKR?-xkr-plb-2-006.jpg   full load breather - no orifice on 03XKR?-xkr-plb-2-007.jpg
Old May 10, 2011 | 04:20 AM
Illustration 4 of the JAG TSB on this shows it perfectly
the hole/orifice is in the tube that leads down towards the valves, appears to be a metal cone like thingy
I will look harder later. Thansk for clarifying and being patient with me!!! I have had the car less than a month and have been learning and doing a ton of reading!!!!!
Old May 10, 2011 | 11:52 AM
SeismicGuy's Avatar
I also have a 2005 XKR and, like Goldlion, I definitely do NOT have anything that looks or sounds like what was described in the how-to about cleaning the part load breather (mine looks exactly like Goldlion's). I think I asked about this a couple of years ago when I first bought my car and someone said the later models do not have the same setup as the older ones.
Doug
Old May 10, 2011 | 03:54 PM
Yep agree
The later models have no orifice...mine is a wide open 3/8 in or so hole
Called the service manager at the dealer...case closed.....
Old May 11, 2011 | 03:13 AM
plums's Avatar
Yep agree
not surprising since "hole"=="orifice" in the dictionary.
Inspector
Oct 17, 2015 12:51 PM
xjrjag
Oct 12, 2015 03:16 PM
zoozth
Sep 29, 2015 07:28 AM
Vector
US Lower Atlantic
Sep 28, 2015 11:08 AM
