Gauges going wild! – Fuel, Temp, Battery, Oil Pressure. Jag 2000 XKR Convertible
The problem began after I jump started the Jag from my other car. I used normal jumper cables from one battery to the other. I have done this a few times as the Jag is my Sunday car.
After the car started I noticed that the needles in the gauges started to float around, moving from low to high rapidly. The gauges in the Minor Instrument panel - Oil Pressure points past the right most mark and stays there, moving back a little; the battery wanders around the number 13. On the Major Instrument pack the Gas and the Temperature gauges move like windshield wipers – back and forth; they never stay in the same place.
I have replaced the battery and did a hard reset a few times to no avail.
Thank in advance for your suggestions!
Check fuses 14 (correction) and 18 in the fusebox on the driver's side of the dash.
If this is not it, and the battery is definitely good, and you defintiely tried the hard resets then your instrument cluster is likely fried.
Last edited by WhiteXKR; 08-25-2013 at 07:38 PM. Reason: Originally wrote 13 and 18, 14 and 18 is correct
You might want to read TSB/Service Action 413-S484.
We replaced DOZENS of backing plates when the SA was issued.
Now I just fold the solder and grind out the back plate so it won't crush the circuit board.(then write an M with a 'sharpie')
I just had a 2000MY XJR in my shop a few weeks ago for a failed INST PK and had to replace it with a good used part. The solder was 'smeared' but removal did NOT fix the problem. (too late, the INST PK was FAULTY)
bob gauff
bob gauff
OGDuarte (08-27-2013)
bob gauff
bob gauff
I have checked every fuse in the car. To do so I disconnected the ground from the battery and used my ohms meter leads - across - every fuse, but found none burned.
My car has fuse boxes:
Under the hood on the front left
Left of the driver side
Right of the passenger side
In the trunk behind the battery
Then I did three Hard Reset for 20 seconds on each of the ignition key positions (I, II and III).
Sorry to report but there was no change in the failure.
Thanks for your help, but keep thinking..
Jump starting a completely dead battery in these cars is not advisable. It is best to disconnect the battery from the vehicle and have the other car or a charger charge your battery for a few minutes.
Used instrument clusters are available on ebay for $100(+/-). I am pretty sure a cluster from a 2000-2002 XKR or XJR will be interchangeable, but you will lose the odometer reading. Alternatively, there ae companies that might be able to repair your cluster (seach instrument cluster repair on Google).
Today I received bad news about my instrument cluster from BBA-Reman who said that the CPU it's fried and they dont have the parts to fix it.
Here are a couple of questions:
1 - Does any one know of another place(s) where the cluster can be repaired?
2 - Can I use a used Cluster from EBAY and have it reprogramed?
Thank you for your help...
The simplest, cheapest solution is to find a used cluster from a wrecked 2000-2002 XKR or 2000-2003 XJR with mileage that is reasonably close to yours. It should plug in with no programming.
Note that an 2000-2002 XK8 or 2000-2003 XJ8 unit will not work without reprogramming.
Earlier years will not fit.
Later years may not be compatible.
OGDuarte (10-21-2013)
More Problems
I sent the cluster to Automotive Scientific Inc over a month ago and I just got it back last week (10/18/2013). I installed and the failure remains the same. Two things could be: ASI did not fix it or the failure is else where.
I am going to buy a used one as per your last suggestion.
What do you think?
What do you think?
have your battery and alternator tested at autozone free.
A bad diode in the alternator will do this, so will a bad cell in a new or used battery.
Also, check clean mega fuses in the trunk for partially blow and clean, thats where the battery is, and a good ground at the passenger side front exhaust, transmission strap.
also I called the dealership, they said to drive it around for a few days, the module that controls your gauges should re calibrate itself after 3 days.
Before doing that, disconnect the red and black battery wires, touch the black wire to the positive terminal on the battery and hold for 30 seconds.
Reconnect and drive for 3 days, if not, they said, their scanner should be able to re-train the car, cost $up to 150
The original poster said he had already tried this. There is no auto recalibration after 3 days.
It appears there is an electrical fault in the car (as you previously suggested) or the cluster is damaged.
OGDuarte (10-27-2013)
Today I installed another cluster that I bought from Ebay. All the gauges worked fine! No more mini windshield wipers!
However a number of errors flashed telling me that a number of things failed in the car and a message warning that "a" wrong part number was installed.
At least now I know that the problem is with the cluster! I will return this cluster ASAP. The company that sold it to me is www.EuropeanAutomotiveGroup.com and they were very helpful!
I found another company that's willing to take a crack at it again! But before I send it I will take the car to the dealer and maybe they can RE-TRAIN the cluster as it was suggested by one of you responders. What do you think? Thanks for your suggestions, you all!
OGDuarte (10-29-2013)
Here is the fix
After all your suggestions, nothing seemed to work. The Jaguar dealer installed a new part and everything started to work as it should. Cost $1,300 (auch!). Lesson to be learned:
Check your user guide before jump starting a dead battery!!!!
Thank you all for your help and suggestions!
Norri (05-29-2014)
BrentGardner
28
04-26-2024 03:08 AM
FS[MidWest]: 08 XKR Convertible 59,XXX miles
MrNobody
08-27-2015 07:49 PM
FS[SouthEast]: 2005 Jaguar XKR Convertible Supercharged
divingmom
08-25-2015 07:54 PM
