Gearbox/Transmission
Old Feb 8, 2014 | 07:39 AM
bt_bob1's Avatar
Default Gearbox/Transmission
Gearbox/transmission .XKR
On hard acceleration up a steep hill I get all the right noise from the engine and rev counter go`s up past 4500/5000 ,but there is little change in the cars speed ?
If you lift off there is a surge forward as the gearbox changes up.
I have over 100000 miles on the clock and no mention of a gearbox oil change.
advice please. Oil change, or worst ?
Old Feb 8, 2014 | 07:53 AM
test point's Avatar
We haven't heard much of failures of the later transmission so at least that is a good sign. Sounds more like low on ATF. For some reason(s) that I have yet to understand there seems to be opinions that high mileage fluid should not be changed. I would change it if it was mine.
Old Feb 8, 2014 | 08:02 AM
Jon89's Avatar
Agreed. An ATF drain-and-fill would be a priority for me given your current mileage....
Old Feb 10, 2014 | 11:57 AM
bt_bob1's Avatar
Well I phoned my Independent Jag garage today .To be told not to waste money changing the oil and filter (He said that was £450 + vat) as it was the cones in the clutch and that it would need a new /reconditioned gearbox costing £2200 + vat.He did say in fairness that he would take some readings, but was certain it was a broken gearbox?
The engine with sport mode engaged will stop revving at 4000 rpm and the car stops accelerating, if I lift off the car will keep on accelerating but in a higher gear?
Old Feb 10, 2014 | 12:32 PM
test point's Avatar
Well, it certainly could be a complete failure but your comment about ' . . . going up a steep hill . . . . certainly sounds like the pressure pump pick up is sucking air when the ATF shifts to the rear of the pan.
Any sign of leaks on garage floor or drive way?.
Why don't you ask them to at least verify that the trans is full to specifications. That couldn't take but a few minutes. They don't even have to let the trans cool to the correct temp. Open the fill port and if only a little or no ATF comes out that is the problem. If it does then it may well be the full monty.
Old Feb 10, 2014 | 02:04 PM
bt_bob1's Avatar
Originally Posted by test point
Well, it certainly could be a complete failure but your comment about ' . . . going up a steep hill . . . . certainly sounds like the pressure pump pick up is sucking air when the ATF shif ts to the rear of the pan.
Why don't you ask them to at least verify that the trans is full to specifications. That couldn't take but a few minutes. They don't even have to let the trans cool to the correct temp. Open the fill port and if only a little or no ATF comes out that is the problem. If it does then it may well be the full monty .o
I have taken it out for a run The box engages reverse perfectly, it engages all gears smoothly I then tried it in manual and it would not rev over 3000 , then I noticed a red flashing light on D. I stopped and switched off the engine,then restart and the flashing was gone ????drove home and the gearbox was again working okay again, except not going above 2500 -3000 revs.
Old Feb 10, 2014 | 02:30 PM
test point's Avatar
There is a 3000 rev limiter on the XKR. No CEL? Get your owners manual out and find out what the red flashing light means.
If the rev limiter is engaging in gear the output shaft sensor becomes a question and I would have surely thought that that would turn on the CEL.
Old Feb 10, 2014 | 02:52 PM
H20boy's Avatar
If you read around these forums, you'll see that our valve bodies are what typically begins to fail...not the hard parts. If you're fluid is not low, you could still be looking at only a rebuilt ZF valve body replacement, which isn't THAT bad, in comparison.
Now, a flashing D on your gear selector, that may be something more serious. You definitely need your codes read to see what is going on there.
Old Feb 18, 2014 | 01:37 AM
bt_bob1's Avatar
On taking my car to a independent he spotted that the hose between the S/C and ecu had developed a hole He has ordered the part about £8 $12 .But is so busy he cannot do the job for 2 weeks
How difficult is it to remove the S/C and the bits, to get access to change this hose
Old Feb 18, 2014 | 05:49 AM
ArtyH's Avatar
So fingers crossed the g/box is O.K. Does this hose carry oil or is it for air? Have you looked at it to see the hole yourself? Are you handy with the spanners? Can you seal ( self vulcanising tape/duck tape ) the hole so you can try the car again and verify if this is the problem? This would only work if the hose was for air obviously, if its for oil you would need to top up to the correct level. IMHO worth doing if you have to wait for over 2 weeks though, I would have to try it to put my mind at rest.
Hope it works out for you.
ArtyH
Old Feb 18, 2014 | 06:53 AM
test point's Avatar
Originally Posted by bt_bob1
On taking my car to a independent he spotted that the hose between the S/C and ecu had developed a hole He has ordered the part about £8 $12 . But is so busy he cannot do the job for 2 weeks
'Hose' to the ECU (ECM)? Hope you misunderstood rather than that being the tech's diagnosis.
Old Feb 28, 2014 | 01:08 AM
bt_bob1's Avatar
Thankfully there was nothing wrong with the gearbox it was a small hose off the back of the S/C with a hole in it. the one on the engine oil fill side.It has been contaminated with oil and had swollen up and burst, Hence the acceleration stopping at about 4000 revs and surging forward as you lifted off and the car changing up a gear.
anjum
Aug 28, 2012 08:41 PM
BusinessConnected
Mar 22, 2008 09:35 AM
