Gen III throttle body failure?
Old Oct 9, 2010 | 11:48 AM
Gus's Avatar
Gus
This is it and I use it all the time http://www.crcindustries.com/auto/co...x?PN=02085&S=Y With NO adverse affects.
Old Oct 9, 2010 | 07:11 PM
Gus's Avatar
Gus
When I apply the Di-Electric grease I use it sparingly. My purpose in using it is to prevent moisture from entering the strike point of the connector eliminating the sporadic operation related to corrosion / oxidation that often takes place on connectors that often disrupts the operation of this and other cars. I also use it to prevent the possibility of tracking in the connectors that could confuse the vehicle operation that is at times related to contamination, moisture and poor connections. If used correctly as the label indicates it will serve you well. Something you need to know, I do not recommend anything I do not use and cannot stand behind. This produce is designated for this use and I will continue to use it this way. Do not let the term Di-Electric confuse you! You can continue to deal with a poltergeist episodes, I will continue to eliminate them in my car.
Old Oct 17, 2010 | 11:25 PM
MarcB's Avatar
Claims adjuster noted 96 "quarter size" (24.26 mm/0.955 in) dents plus the shattered windshield; I hope I get it back before Christmas! It is driving season here and the repair shops are backed up with all the recent damage.
xjrjag
Oct 24, 2024 03:09 PM
Gus
Oct 15, 2019 12:29 PM
ajacks86
Oct 12, 2017 08:51 PM
mrplow58
Sep 9, 2015 11:27 AM
