Green Shower Part 2
Old Sep 29, 2017 | 03:54 PM
VAXKR's Avatar
Default Green Shower Part 2
In an over abundance of caution, I took apart my latch system when I noticed the first drop of hydraulic fluid. As you can see, the leak seems to be very minimal, however, the issue seems to be that I do not know where it is originating from. My guess is the hydraulic ram as the connections look dry - any advice?
Attached Thumbnails Green Shower Part 2-img_3626.jpg   Green Shower Part 2-img_3625.jpg   Green Shower Part 2-img_3622.jpg   Green Shower Part 2-img_3621.jpg   Green Shower Part 2-img_3620.jpg
Old Sep 29, 2017 | 04:05 PM
If it were me - just looking at the hoses - it is only a matter of time before they separate from the connector and you have a true green shower. Recommend replacing hoses and having top hydraulics rebuild the latch ram.
I would check the hoses and lift rams as well. A complete set of hoses from either Top Hydraulics or Cabriolet Hydraulics run around $600. Top Hydraulics will rebuild rams not sure about Cabriolet Hydraulics.
Old Sep 29, 2017 | 08:28 PM
Jandreu's Avatar
Mine was leaking no just a tad from the plunger seal.
Old Sep 30, 2017 | 06:52 AM
VAXKR's Avatar
Is there residual pressure in the ram? I ask because I want to disconnect it and send it out for repair, wondering if there is a procedure to release the pressure?
Old Sep 30, 2017 | 07:08 AM
release pressure at the pump by turning petcock counterclockwise, then you are ok to remove the rams, hoses.
Old Sep 30, 2017 | 10:18 AM
VAXKR's Avatar
I was able to bring the hoses and ram outside the car while still connected to minimize my interior getting damaged. Was actually very easy to do, I took the entire tray off as well, Sent my ram to Top Hydraulics and will be getting front hoses as well
Ram ready to ship
I did all the removal outside the car
the tray containing the complete latching system comes out easily
