Gross leak
Old Feb 20, 2015 | 02:03 PM
macs99's Avatar
Default Gross leak
Keep getting code P0455 car running smooth. can't find any vacum leaks, car just passed smog this week.any help would be appreciated thank Walter.
Old Feb 20, 2015 | 02:27 PM
Walter,
I've moved your question from General Tech Help to XK8/XKR forum. Members here with the same model will be able to help.
Old Feb 20, 2015 | 03:03 PM
brgjag's Avatar
that is a evap code related, purge valve, somewhere along those lines.
Old Feb 20, 2015 | 03:08 PM
plums's Avatar
It can be the gas cap. Did the emissions facility use a gas cap tester and damage
the gasket in doing so?
The other culprit is the hose connection at the canister. Dont' know where it is
on your car.
Old Feb 20, 2015 | 03:57 PM
macs99's Avatar
Default gross leak
Smog station did do pressure test, will check gas cap and purge valve.Thanks for the info much appreciated.
Old Feb 20, 2015 | 04:12 PM
brgjag's Avatar
their tests may have made a old part finally fail??? Just funny that this happens soon after a test as these. I bet an old part somewhere along the line has pooped out. My money is on one of the valves.
Old Feb 20, 2015 | 04:28 PM
macs99's Avatar
Default gross leak
Thanks for your input will check valves and lines tomorrow,probably worth replacing after 16 years would be one less headache.thanks Walter.
Pristine97XK8Convertible
Mar 5, 2025 10:32 AM
Poet
Oct 2, 2015 09:00 AM
ahunt4
Sep 25, 2015 03:43 AM
Tim Goz
Sep 17, 2015 09:11 AM
jaggermang
Sep 8, 2015 07:07 PM
