hard reset ecu how to do it
Old Nov 6, 2013 | 08:38 AM
smorgan's Avatar
Default hard reset ecu how to do it
Stuck in valet mode black key no fob. Can anybody help?
Old Nov 6, 2013 | 08:57 AM
RJ237's Avatar
When I use valet, I just use the key to unlock the trunk and it cancels valet. If you need to do a hard reset, disconnect the negative battery terminal and touch it to the positive post for a few seconds.
Old Nov 6, 2013 | 09:01 AM
RJ237's Avatar
Welcome to the forum, when you have time please visit the new member area and introduce yourself. I believe you will learn how to add your signature and car info there.
New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum
Old Nov 6, 2013 | 09:23 AM
A hard reset won't clear Valet Mode ...........
............. and you need to get into the luggage compartment to disconnect the battery for a hard reset.
Use the Black headed key to open the luggage compartment as suggested in post #2 and this will cancel Valet Mode.
If you don't have a Black headed key or the luggage compartment lock is seized, post back here.
Old Nov 6, 2013 | 09:39 AM
Windycityx's Avatar
My key won't open my boot on my 97' any suggestions?
Old Nov 6, 2013 | 10:23 AM
It won't go right into the lock or it does fit but then won't turn?
Before moving on to more drastic measures involving drilling holes, it's worth spraying penetrating oil or aerosol locksmith's graphite into the lock and then inserting the key and moving it left to right repeatedly to try to free it up. A little force can be used but not too much to risk shearing the key.
So many get caught out with this lock seizing up because it almost never gets used. once you get it freed, you'll always remember to check it from time to time to avoid this happening again.
ericjansen
Dec 19, 2021 12:20 AM
jeremys
Sep 30, 2015 06:37 AM
drgrcr
Sep 25, 2015 10:31 AM
GGabriel
Sep 18, 2015 08:44 PM
mrplow58
Sep 9, 2015 11:27 AM
