Having a tough time with this connector
Old Aug 2, 2015 | 04:32 PM
Dallas XK8's Avatar
Default Having a tough time with this connector
I'm removing the (front) seat belt tensioners on m y 2001 XK8 convertible, and I'm baffled by this connector. (Almost all of my DIY experience has been with GM, Mazda and Mini Coopers, and I can't figure out how to unlatch this one.)
I'm reluctant to pull too hard on this one, because I'm not sure where exactly it comes apart, and I really don't want to break it. I moved the yellow "slider" to the alternate position, but then what? Pinch? Pry? Pull? Twist?
Old Aug 2, 2015 | 04:52 PM
Dallas XK8's Avatar
Ok, I figured it out (but not the Forum's "delete" function yet).
Anway, you slide the yellow slider, then simultaneously press a tiny black plastic square on each side of the connector where the yellow tab was originally. (The second tab, closest to the fabric of the seat belt, cannot be seen…only felt).
As you were...
Old Aug 2, 2015 | 05:11 PM
I've moved your thread from General Tech Help to XK8/XKR forum. This is the place to post tech questions about your model.
Bcrary3
Sep 12, 2021 05:41 AM
Sprayall
May 30, 2021 08:13 AM
cissdm
May 3, 2016 06:02 AM
KarimPA
Sep 12, 2015 08:15 AM
Sprayall
Sep 3, 2015 07:49 PM
