Hazard lights - RESOLVED
Old Feb 22, 2018 | 07:31 PM
steve scott's Avatar
Default Hazard lights - RESOLVED
98 XK8 Recently acquired vehicle, finding hazard lights are blinking, as they should, BUT, I can't get them to go off. Pressing the button doesn't work. Button seems to not move. Thanks for help. steve
Last edited by GGG; Feb 23, 2018 at 06:09 AM. Reason: Add 'RESOLVED' to thread title
Old Feb 22, 2018 | 07:57 PM
Johnken's Avatar
Steve, sounds like the button is stuck. I've read many posts about fog light buttons not working properly. Fiddling around on off on off sometimes clears them.
I bet you tried that though. Looks like you are new here, welcome. I'm going to run a search for you. Be right back.
John
Old Feb 22, 2018 | 08:01 PM
Johnken's Avatar
From previous posts: Looks like it's probably mechanical. Use a pair of credit cards to wedge under button and pull out.
Could be weak return spring. If you can't fix, pull the fuse so battery doesn't drain.
Let us know how you do.
John
Old Feb 22, 2018 | 08:16 PM
Lady Penelope's Avatar
There was a post I believe on the X308 section on this as they may be the same .
Old Feb 22, 2018 | 08:21 PM
Johnken's Avatar
Parker I wouldn't be surprised. After I answered above, I must have run across 3 more discussions about this. Apparently it happens a lot.
John
Old Feb 23, 2018 | 02:25 AM
Welcome to the forum Steve,
As suggested in earlier replies, the button will just be sticking.
Old Feb 23, 2018 | 03:15 AM
Default hazard lights
Thanks everyone. The credit card did the trick...I can go to sleep now.
Old Feb 23, 2018 | 08:28 AM
Roger_B's Avatar
Just FYI, here's the most recent thread which addresses some more permanent repair ideas...
https://www.jaguarforums.com/forum/x...-stuck-196267/
JimC64
Sep 22, 2025 02:52 PM
Don B
General Tech Help
17
Aug 8, 2017 09:11 AM
Drossvet
Oct 21, 2016 09:27 AM
Jeff DeVere
Oct 13, 2016 07:00 AM
Don B
General Tech Help
Nov 9, 2015 12:59 PM
