Headlamp Adjustment
Old Jul 16, 2015 | 10:54 AM
DevonDavid's Avatar
Default Headlamp Adjustment
For reasons which have much to do with a minor collision with a deer a few weeks ago, I have had to remove and replace my front bumper (fender ?) and headlamps.
I can't find anything in JTIS about how to check and adjust the alignment after putting the lights back.
There are two things that turn - the large knob on the rear of the motor which raises and lowers the dip beam, and the smaller white plastic rod - see arrows on photograph.
Can anyone point me to the correct bit of JTIS, or somewhere with instructions on how it is done.
Many thanks,
David.
Old Jul 16, 2015 | 01:18 PM
Pristine97XK8Convertible's Avatar
Default Headlamp adjustment
Sorry to hear about your encounter with a deer...
My 97XK8 does not have the motorized front headlamp adjuster as yours, but I would still like to hear from esteemed members on this forum as to how to adjust my headlamps
Many thanks,
David.
Old Jul 16, 2015 | 01:33 PM
Johnken's Avatar
Gosh that's funny I've been meaning to do the same thing too. I didn't even know there were motorized ones for 1997 and/or 1998. I look forward to the instructions as well. I was just thinking about this last night when I turned off the fog lights - my low beams alone are barely useful. It will be nice to get them right.
So, if anyone knows how to do this, please chime in and thanks.
John
Old Jul 16, 2015 | 09:35 PM
vettegood's Avatar
+1 Please advise us all, if you know how.
Thanks.
And Remember
Happy Motoring...
Old Jul 17, 2015 | 02:55 AM
.......... I have had to remove and replace my front bumper (fender ?) and headlamps.
Can anyone point me to the correct bit of JTIS, or somewhere with instructions on how it is done. .......
David,
I believe the 'fender' is the wing. Best to avoid any attempt at the American automobile lexicon. Before you know it you'd be involved with 'trunks' (part of a elephant) or 'hoods' (dubious characters from Chicago or NY).
I also can't find any reference to headlamp adjustment procedure on the 4.0 litre models in JTIS.
The adjuster is the round black knob. I think the white/knob/rod is for the headlamp level rotary switch in the centre console.
This should be set to position '0' when aligning the headlamps.
Old Jul 17, 2015 | 05:49 AM
DevonDavid's Avatar
As with all things Jaguar, I think it's quite complicated - I'm still looking for information, but so far seems like ..........
Some cars, right from 1996/7, have a manually adjusted levelling mechanism - these are identified by a "bubble level" and a sort-off slotted adjustment bracket under the clear plastic cover on top of the light unit. There are two little white 7mm (??) plastic hexagon nuts like the one in my photograph to set horizontal and vertical position. Paul Pavlik has a post on roadfly.com with the detailed instructions -
headlight assembly adjustment
This seems to apply to US cars - can someone confirm or not whether there's a dash operated knob for headlight adjustment on these cars as in Graham's post - if there is, I can't see how it can work as there doesn't seem to be any electrical connection and I can't think it's mechanical.
On my car (1997) - maybe all UK cars ?? - there's an actuator motor on the back of the lamp unit with a separate three pin connector. Inside is an electric motor and quite a complicated printed circuit board (I just took one to bits !!)
I think you set the level (with headlights on) using the big black knob, and then when you switch off, the headlights automatically lower. The little knob on the dashboard gives "fine tuning" to this default setting depending on loading in the car.
The other knob (little white one) is, I suspect, for horizontal adjustment, but I need to verify that by trial and error.
My car has "retrofit" HID bulbs, but I have always assumed that the headlight unit is the original 1997 Jaguar installed kit.
Will keep looking.
Old Jul 17, 2015 | 06:09 AM
........ I think you set the level (with headlights on) using the big black knob, and then when you switch off, the headlights automatically lower. ...... My car has "retrofit" HID bulbs, but I have always assumed that the headlight unit is the original 1997 Jaguar installed kit.
Will keep looking.
My 2001 XK8 was standard headlamps with the rotary level switch in the console. The headlamps did NOT lower when the ignition was switched off.
My 2005 XK8 had HID's with 'self levelling'. The beam would rise when the ignition was switched on and lower when it was switched off.
It sounds like you may have a PO hybrid.
Old Jul 17, 2015 | 07:53 AM
DevonDavid's Avatar
Graham.
Confusing isn't it ??
What I can't work out is .............. on my 1997 wiring diagram, it shows a separate circuit, on a separate page, for "self levelling cars" which is the "centre console switch pack" (dashboard knob) and the actuator motor on each headlight unit. Nowhere in any of the other diagrams in the same 1997 wiring guide is there a schematic for a car without the actuator, but *with* the console switchpack.
Here's my guess - please contradict if you know different and maybe we can end up with a definitive answer - or maybe I need to get out more ....................... :-)
For legal or other reasons :
US cars (and other parts of the world) were fitted with "ordinary" halogen bulbs in "ordinary" metal reflectors for both main and dip beams. These are adjusted manually as in Paul's roadfly thread, and have no centre console adjustment knob.
There may have been an option to "upgrade" to ................
UK cars were *either* as above, *or* were fitted, on dipped beam, with "ordinary" halogen bulbs but with a "projector type" lens for better performance. Regulations dictated that these MUST have a self-levelling mechanism. They also have the centre console switch.
It is easy to retrofit HID bulbs to these types of reflector, but they are, at least in theory, illegal on mine because I do not have headlight washers which I believe are mandatory on HID headlights in the UK. Main beam (OEM) is "normal" halogen bulb as with US cars.
Photos show inside of actuator :
Old Jul 17, 2015 | 08:27 AM
David,
According to the Parts Catalogue, Canada/USA XK8 headlamps are different from RoW (Rest of World). I've posted only non powerwash here as that it your type:
1. Canada & USA
2. except Canada & USA
Within this category, Japan has yet another specification.
Although interesting, I don't think it's going to help resolve the mystery of your setup!
Old Jul 17, 2015 | 09:09 AM
DevonDavid's Avatar
Graham.
But it does .................. mine is exactly as in the second diagram except that a previous owner has changed 6 & 9 (the dipped bulb and holder) to a HID Xenon set up with external ballast etc. I guess because of different regulations in different countries, there are numerous (US, Canada, Japan, UK, Europe ?) different headlamps. US / Canada cars don't have the actuator and self-levelling "by default".
The only thing it doesn't explain is your 2001 car and maybe other years / models which would seem to have the console levelling knob, but no external actuator as in my photographs. Maybe there's a much smaller motor inside the light unit, but it doesn't show on any wiring diagram I can find.
Anyway, I think I know how to set mine now - for anyone in US / Canada - use Paul Pavliks post (link above) for full instructions on how it's done on your cars.
Cheers,
David.
Old May 28, 2021 | 07:55 AM
tlindi's Avatar
Talking Headlamp Leveling Actuator JLM12117 Internals
If anyone is interested how those actuators work and how their internal components may be repaired - attachment has circuit diagram, component lists and PCB component layout.
These actuators are only on European cars and I could not find part near me so I reverse engineered content to be able to fix electrics - (one circuit board connection was bad - in visible to eye).
Depending of position of leveling switch in center console CTRL input voltage to actuator varies between 8 and 11 Volts - and actuator changes postion accordingly.
Br, tlindi
Graham.
Attachment 115722
Attachment 115723
Last edited by tlindi; May 28, 2021 at 09:00 AM. Reason: Revised attachment updated - yet again
Old May 30, 2021 | 12:53 AM
Pistnbroke's Avatar
Park vehicle 25 ft from a wall or garage door . Cover one headlight ... The beam kink in the pattern should be 4 inches down and aligned with the centre of the lamp unit. Only HID units require self-levelling in the UK .. I have had HID fitted for years and never been stopped
Old May 1, 2023 | 01:05 PM
tomfurie's Avatar
Headligh assembly adjustment instructions link seems to be broken. (DevonDavid post #6)
If so, please post link to new location.
- Thanks.
Old May 1, 2023 | 06:04 PM
Johnken's Avatar
Headlamp adjustment
Park on level surface. Check with level on open door door sill.
Pull the plastic access panel off (hood open to service position look for panels above headlight area). This is the panel you would pull to replace high beam bulb.
See tiny bubble level inside on headlight housing.
Turn white plastic adjustment pieces to get bubble in level centered. As I recall a tiny ratchet makes this easy.
John
Old May 2, 2023 | 04:33 AM
Pistnbroke's Avatar
Cannot find bubble and ratchet on my 97.....the adjust is a knob on the back of the electric motor for the dash up down controller
For UK its beam kink 4 in down at 25 ft but US cars have a squarer lift to the beam
Old Apr 11, 2024 | 10:29 AM
BlueSmudge's Avatar
Default Blown Headlight Levelling fuse...
Hope I'm on the right thread here, but looking for some help if possible! My 2002 XK8 failed its MOT yesterday on 2 counts. Firstly the rear fog lamp 'tell tale' doesn't light up when the fog lights are on. Is that a simple (?) switch/bulb replacement?
Secondly the headlight levelling didn't work on either headlight. When I got home, I checked the fuses and the Headlight Levelling Fuse (F3) was blown. I replaced it and started the engine. Pretty much immediately I was aware of some smoke coming from under the bonnet coupled with a pretty unpleasant 'burning' smell. I turned the engine off and opened the bonnet. I couldn't discern where the smoke and smell came from but the fuse had blown again! I'm pretty sure that I've never adjusted the headlight levelling switch but either way, I'm a little scuppered in terms of getting a new MOT before I get this sorted. I've watched a few YouTube videos of people accessing the headlights etc. and it looks a pretty onerous process, but before I do anything, has anyone got any ideas as to what might be happening here? It passed the MOT with no problem last year and as I said, I've never adjusted the switch! What could be casing the burning smell and the smoke? Any assistance is appreciated!
gdrag
Jul 4, 2025 06:10 PM
slmskrs
Jul 5, 2015 02:12 PM
anewby67
Mar 11, 2015 07:48 PM
rhathaway
Oct 28, 2013 06:39 PM
snaproll
Jan 20, 2009 05:16 AM
