Headlight Horizontal Alignment - 2002 XKR
Old Oct 20, 2016 | 10:27 PM
Roger_B's Avatar
Default Headlight Horizontal Alignment - 2002 XKR
My headlights were aimed so low that I wondered about the extensive front suspension maintenance the previous own claimed to have had done.
I combed the forums and found how easy it is to adjust vertical headlight alignment in a thread from 2009. What I cannot find in forums or manuals is where to look for the adjustment for horizontal alignment. (These are standard projector low (dipped) beams, not HID.)
Much obliged for any help!
Old Oct 22, 2016 | 08:05 AM
Roger_B's Avatar
I conclude that the dead silence means...
1) This cannot be done
2) No one actually knows how (most unlikely unless #1 is true)
3) I have used up my quota of "newbie" questions...
Old Oct 22, 2016 | 09:55 AM
Johnken's Avatar
When you say aimed so low, I think vertical adjustment. Do you need to point them left right along the horizontal ?
Here's what I found on my 98:
Yes there is a separate horz adjustment, I never used it.
Low and high beam adjustments are inseparable. They adjust together for vertical. You are stuck maximizing both, not a perfect set up for my low beam coverage. I did spend the $50 for those "extra" bright lights - waste of money. Barely discern the difference.
Different years have different lights, so I can not add any more for your 2002.
Old Oct 22, 2016 | 01:04 PM
Roger_B's Avatar
You understood correctly. The vertical was easy, but I need to move them to the left. Can you tell me where to look for the horizontal adjestment?
Old Oct 22, 2016 | 01:22 PM
Johnken's Avatar
https://www.jaguarforums.com/forum/x...ustment-12354/
Check this link out. John
Old Oct 22, 2016 | 01:23 PM
Johnken's Avatar
It was from gdrag 3/16/2009. Search for his post if link no good.
Old Oct 22, 2016 | 01:50 PM
Roger_B's Avatar
Thanks, John! I had read that thread, but it appears to pertain to X150 but not X100. Have you found the adjustment as they described on your '98 XK8?
Old Oct 22, 2016 | 02:42 PM
Johnken's Avatar
Oh darn I didn't realize it was a 150. I never tried to adjust horz on mine sorry. I do recall seeing instructions for it I'll take a look in my documents later. Hope I can find it. John
Old Oct 22, 2016 | 03:09 PM
oyster's Avatar
Hi.
Different lamps for different model years and markets make this very confusing.
Maybe the following attachment can help you.
Attached Thumbnails Headlight Horizontal Alignment - 2002 XKR-headlamp-1.png   Headlight Horizontal Alignment - 2002 XKR-headlamp-2.png
Old Oct 22, 2016 | 05:10 PM
Roger_B's Avatar
BINGO!
Thanks, Oyster! I was able to get to the adjustment screw on the left side. There seems to be a dull white cylindrical plastic cover over the whole adjustment assembly on the right side, but now I know what I'm trying to access. You've given me exactly what I needed. This forum is amazing...
