heater/ac blower
Old Oct 14, 2023 | 12:26 PM
olphart's Avatar
Question heater/ac blower
2003 XK8 Convertible
Not sure if this is a real issue or not. On max blower, I can hear the fan blowing quite enthusiastically, but the air coming out the vents seems pretty weak in comparison. Both the heat and ac work fine, but in really cold/hot weather, I'm not sure they'd be all that effective. I haven't had it out in very warm or cold weather yet. But on a 27 C day the ac comes out cold, but not much blowing. I don't remember my previous XK8's being like this.
Anyone else have this problem?
Old Oct 14, 2023 | 12:33 PM
motorcarman's Avatar
Are BOTH blowers operating???
Old Oct 14, 2023 | 12:34 PM
olphart's Avatar
There are two? I wasn't aware, and not sure how I'd check...
Old Oct 14, 2023 | 01:38 PM
olphart's Avatar
Air is blowing out both sides of the dash, just not very strongly
Old Oct 14, 2023 | 04:31 PM
The two blowers are directed into the central climate control box.
If a blower fails, the blower housing is just a GIANT AIR LEAK for the other blower.
Old Oct 14, 2023 | 06:08 PM
olphart's Avatar
That sounds like it could be that.
Old Oct 16, 2023 | 08:54 AM
fmertz's Avatar
Each blower has its own fuse located in the door jamb fuse box. Each one can be removed/reinstalled in turn for identification.
Best of luck, keep us posted.
Old Oct 17, 2023 | 07:38 AM
STLTHMSTA's Avatar
Well DANG IT!! I've got something else to add to the list of things to do/check. I have the same situation, the ac/heat works, but meh? TM
Old Oct 17, 2023 | 07:39 AM
olphart's Avatar
Well in my case it wasn't the fuses...DAMN! that would have been easy.
Old Oct 17, 2023 | 10:25 AM
fmertz's Avatar
The larger point I was trying to make is that the fuses can be removed one-at-a-time to double check that each individual blower is actually running, moving air, and listening to what it sounds like in relation to the various options for the vents (Face, Recirc, etc.). It is harder to tell when both blowers are running together.
My own car also has an issue in that area. Only the Face and Recirc settings give plenty of air flow. I tested 1 blower at a time, and 1 of the 2 sounds "normal", the other produces more white noise and sounds like the airflow is somehow obstructed. I have yet to spelunk into the foot wells to diagnose further. FWIW, eBay sellers for these parts generally have great pictures showing the layout of the system.
Swagger XC
XJ XJ12 ( X305 )
21
Sep 17, 2021 12:21 AM
Kevin Drain
Aug 20, 2021 12:22 PM
Neil1664
Sep 1, 2013 12:45 PM
MLRocafella85
Jan 25, 2011 09:33 AM
