Help 2: parking sensors only work 1/3 of the time
Old Jan 31, 2011 | 10:43 AM
Frog's Avatar
Default Help 2: parking sensors only work 1/3 of the time
My rear parking sensors only seem to function every third time I reverse. I reverse up to a nice clean plaster wall in my garage, but I don't get the beeper every time. It's annoying because I can never rely on the system for guidance now.
Any ideas for a quick fix?
Thanks.
Old Jan 31, 2011 | 12:25 PM
AlexXK8's Avatar
Turn the ignition on without the engine running. Put the car in reverse. Put your ear next to each parking sensor, the ones that work will emit a very faint high pitched sound. The one that doesn't work will be silent. The outer two are easier to replace than the inner two, good luck.
Old Jan 31, 2011 | 02:06 PM
WhiteXKR's Avatar
The reverse parking aid has a self test feature of sorts. If it detects a failure in the sensors, its communication or itself, it sounds a 6-8 second continuous tone the first time reverse is selected after the ignition is turned on.
If your car is NOT doing that, then I would suspect it might not be sensing your shift to reverse reliably. Since the signal it uses to sense reverse is the same wire that drives the back-up lights, the next thing I would check is to see if your backup lights are working every time.
Old Feb 1, 2011 | 01:44 AM
Frog's Avatar
Fantastic advice, many thanks. I have only been a member here a few days and already feel right at home
I will run through the sensor checks you mention and get back to you.
Old Mar 24, 2011 | 11:32 AM
Tiko89's Avatar
Default Speaker?
My sensors don't work at all. Brutal checked them and thought I had one out (inner, driver side), but I don't get a warning message or tone at all. Doesn't the system have a dedicated speaker for that? Where is it? I'm wondering if it's broken.
Old Mar 24, 2011 | 12:10 PM
WhiteXKR's Avatar
There is a plastic panel, square with rounded edges between the console rear and the back seats. The speaker is on the backside of the panel. The panel just pulls off (you gotta pull hard).
Old Mar 24, 2011 | 12:53 PM
abraxus's Avatar
I have third party parking sensors fitted, so not sure if the same applies to yours, however I had problems with mine and apparently you can reset them.
The procedure for mine was to switch on the ignition and then go in and out of reverse 5 times. I tried this and mine have worked fine since.
Old Mar 27, 2011 | 10:20 PM
Tiko89's Avatar
Today I tried Abraxus's reset procedure, then listened to the sensors. They were all making noise, so I backed the car very near a wall. I could hear, faintly, a tone coming from the console. Is there some kind of volume setting for this speaker, or does this indicate a problem with it?
Old Mar 27, 2011 | 10:29 PM
WhiteXKR's Avatar
No there is no volume control. Sounds like there may be a problem with the speaker, the wiring to the speaker or the backup module's speaker amplifier.
Old Apr 8, 2011 | 09:21 PM
mbenvo's Avatar
Thank you for the great advise to listen for the ultrasonic pulses.
I have found that the center sensor on the drivers side is not making any sound, and the other once are making the pulsing noise.
I tried to get the sensor out by pushing it out from inside the bumper, and it comes out about an inch and not any further. How do I remove that sensor from the bumper so I can replace it?
Do I have to get the new sensor painted? Does anyone have a part number for it?
Any help greatly apprecaited.
Thank you
Mike
Old Jun 26, 2011 | 12:54 PM
marco_hevia's Avatar
I have a problem with my parking sensord too, i have a jag, s-type 4.0, and everytime you put it on reverse it makes a beep around 4 or 5 seconds...after a lil bit of research i found that that beep indicates a mailfuncion status of the system, but i ve found in the trunk two big plugs, unplugged and i was wondering if someone knows where is the parking aid system console, to see if these plugs belong there.... Any ideas??
By the way appologies for my bad english, and thanks in advance!
Old Jun 26, 2011 | 01:21 PM
Marco,
You would be better asking in the S section, but to answer your question, the module is fixed to the left side of the spare wheel well.
Old Jun 29, 2011 | 03:21 PM
Tiko89's Avatar
I pulled the speaker and fiddled with it. It was definitely louder when I plugged it back in but was still too soft. Can I swap out another speaker? Where is the amp located?
stanjag
Dec 29, 2024 08:26 PM
BrentGardner
29
Dec 16, 2024 12:13 AM
johnnie ryall
Oct 19, 2015 09:44 PM
tberg
Aug 31, 2015 04:33 PM
stetson1
Aug 27, 2015 07:49 AM
