help!!!
Old Aug 11, 2019 | 05:05 PM
pancula's Avatar
Default help!!!
evrything workd fine.... stopped the car and after 5 minutes it wont start.... everythin othwr is working... light,radio, wipers.... it gaves click sount.. checked starter it works, battery is good..dont know what else to check... car has 60000 km ..
Old Aug 11, 2019 | 05:16 PM
Gus's Avatar
Gus
Move your shifter to "N" and try it again.
Gus
JagRepair.com - Jaguar Repair Information Resource
Old Aug 11, 2019 | 05:22 PM
pancula's Avatar
Gus
tried but no reaction (
Old Aug 11, 2019 | 05:29 PM
Gus's Avatar
Gus
See if the information on this link helps.
Link. JagRepair.com - Jaguar Repair Information Resource
Gus
Old Aug 11, 2019 | 07:19 PM
avern1's Avatar
You might want to check the battery connections. Make sure they are tight. Next you will want to know what the battery level of charge is. It is possible to start a car on a weak battery and shut it off before the battery has had a chance to recover from the starting draw and then it won't crank.
It is a Jaguar, all problems begin at the battery.
Old Aug 12, 2019 | 01:10 AM
pancula's Avatar
yeah but i tried another one from my second car.... 100 amp but still the same
Old Aug 12, 2019 | 01:26 AM
coronets's Avatar
This does sound like a starter going out. How did you check that the starter is working?
Old Aug 12, 2019 | 02:57 AM
DavidYau's Avatar
Default Is the engine cranking?
Sorry to ask dumb question but you said you hear click. Does it crank?
Maybe kill switch has tripped. Check dash LHS for inertia switch.
Old Aug 12, 2019 | 03:56 AM
pancula's Avatar
removed starter and checked ... it engages and works fine
Old Aug 12, 2019 | 03:58 AM
pancula's Avatar
also tried but no any result
Old Aug 12, 2019 | 11:48 AM
Mad Hatter's Avatar
If you put a wrench on it, can you get the crankshaft to spin?
I think you see where my thoughts are going.
If you have tested that the wiring to the starter works and the starter spins when it is off the car, but you only hear the start solenoid clicking when it is attached....... Maybe the rotating assembly is not free.
Old Aug 12, 2019 | 12:21 PM
jazzyjags's Avatar
I would hope that's not the case. I ended up with a cracked 24mm stainless steel socket from mine....
As mentioned, check everything before you jump to that conclusion. I thought it happened a 2nd time a few months back, but it wasn't nearly as bad, turns out my supercharger got something in the rotor assembly and was locked up and wouldn't let the crank pulley spin, therefore I just got the dreaded "click" as well. Once I removed the supercharger belt, the crank turned and I was able to isolate the issue.
Check other accessories to make sure there inst anything else locked up, remove the belt before you turn by hand.I doubt that if it was running just fine a few minutes before, the engine would seize up all of a sudden like that.
Old Aug 12, 2019 | 12:42 PM
DavidYau's Avatar
Sorry to ask dumb question .... Does it crank .
Still not clear on your non start problem. Does it crank?
Old Aug 12, 2019 | 04:30 PM
Gus's Avatar
Gus
First what year is your car? You say that the wipers and radio work and you hear a click is that at the starter? You say that you removed the starter and bench checked it so it does not sound like the starter but can be the power to the starter. In the trunk you have 3 high power protection fuses and the one to the starter could be blown. You need to check the voltage at the starter from the battery.
Old Aug 15, 2019 | 02:18 PM
jazzyjags's Avatar
Any update on this one?
Johnken
Jul 24, 2014 01:08 PM
Bob OB
Jul 14, 2013 05:55 PM
sjaurora
Jul 31, 2011 08:34 PM
bobbyjackson
May 7, 2011 10:49 AM
Jagxtypeowner
Jan 11, 2010 04:18 PM
